Page 2 of 2 FirstFirst 12
Results 26 to 50 of 50
Thread: Anyone ever used syncromesh??
    1991 Civic STD
    Arbutus, MD, Baby
    Re: Anyone ever used syncromesh??
    Quote Originally Posted by 89AccordResto
    You use engine oil in your transmission!?
    Yeah, that's what you're supposed to do for a manual. At least for a 3G manual.
    Daily Drivers Done Right
    3Geez Veteran gfrg88's Avatar
    1986 Honda Prelude 2.0Si-T
    A Mile High.
    wait, so everyone on here puts regular motor oil in their trans????:wt:
    -Gio
    My E85 Turbo Build
    5280FEST
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    I use sythetic oil, 10w-30. Looks like all the additives aren't worth a damn & one person had bad results with syncoshit, I mean syncromesh.
    A Mile High.
    what about 20w-50??? does it have to be sythetic?? i never knew we could use regular oil so thats what im asking (i feel like such a n00b )
    -Gio
    My E85 Turbo Build
    5280FEST
    Banned
    89 Honda LX
    Beertown, USA
    Weird. Allt eh manuals I've used required manual transmission fluid.
    LX User Mars's Avatar
    Feb 2005
    1989 LXi Coupe
    Dallas Tx
    ive ehard that motor oil works but tis better to use thicker stuff
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    Thicker oil should be the way to go. I used what was free, upgrade in the future. Had some kind of gear oil in it when I bought it.
  8. #33
    1988 Honda Accord Lxi
    Hey, Just wanted to say this, I used Royal Purple Synronizer something cant remember what it was called and replaced my transmission oil with it 3 quarts i think, because my 1st to 2nd gear would grind at high RPM and it was hard to get it in gear it wouldnt just fall in... So i put that stuff in it worked really good for like 2 weeks and then it started coming back but im gonna get a new tranny anyways so i dont care but i do use royal purple oil in my car that stuff is fuckin sweet i think (I know oil is oil) but i think it runs alittle smoother and better with it
  9. #34
    Banned
    89 Honda LX
    Beertown, USA
    Royal purple isn't all that and a bag of chips. Search for oil tests.
  10. #35
    1991 Civic STD
    Arbutus, MD, Baby
    My tranny's had motor oil in it, since I got it, pretty sure it was 10W-40. I might switch to something thicker after reading this thread, though, especially since 3rd gear is starting to grind due to the abuse my mom and aunt put on the car before I got it a few years ago.
  11. #36
    Feb 2005
    1989 LXi Coupe
    Dallas Tx
    I think i might pick up something like synchro mesh, my tranny has been grinding a little going into 3rd at higher rpms.
  12. #37
    I used syncromesh on a tranny that was grinding first, second, and third. Now the tranny has no grinds and shift very smooth. I used 2 1/2 QTs, because you are suppose to completely replace your tranny oil. Also I never even heard of manual transmission oil, all I ever used was motor oil for a manual tranny.
  13. #38
    Banned
    89 Honda LX
    Beertown, USA
    Usually it's gear oil. But not engine oil. THat's just weird.
  14. #39
    1991 Civic STD
    Arbutus, MD, Baby
    You're just weird.
  15. #40
    Nov 2002
    Ridin Dirty in New York
    you can use 10w30, but in honda trannies it tends to make them feel notchy. Honda MTF is the best stuff to use if youre tranny is in good condition. If you have a bad grind, i dont care what crazy ghetto bob says, syncromesh is the shit
  16. #41
    Banned
    89 Honda LX
    Beertown, USA
    Yeah. If I was going to flush my transmission I'd use the factory transmission oil.
  17. #42
    Mar 2006
    RTFM (Read The Fxking Manual) Honda specifies 10-40 MOTOR OIL. I changed mine this past weekend and added some lucas transmission fix and it seems to work quite well.
    Honda as since switched to its own blend of MTF. Several folks I have talked to say it quite good and works fine in their G3 Accord.
    I wonder what the viscocity of the Syncormesh is? Any body seen a rating for it?
    Once again do not put heavy gear oil in a Honda tranny unless you want to kill it. It is a leading cause of the dreaded 5th gear failure due to the fact that it is too thick to make it all the way up to that gear from the pool at the bottom. Of course the leading cause of 5th gear failure is not having enough oil in the tranny.
    Paul
    89 LXi 5sp Coupe 230k and going strong....
  18. #43
    Banned
    89 Honda LX
    Beertown, USA
    Quote Originally Posted by pmpete
    Hope you weren't using synthetic.
    http://www.bobistheoilguy.com/images/lucas/lucas.htm
  19. #44
    Mar 2006
    No I won't waste my money on that expensive shit. When good old Dino oil will do the trick with a little help. Beside if you have any leaks Synth will find a way to wiggle out them.
    Paul
  20. #45
    2.0Si User cubert's Avatar
    Feb 2003
    2012 Civic si, old bikes.
    NH
    i had 80w90 in mine...only time i had trouble was when it was stupidly cold out and the 1-2 shift was a bit sluggish...but once the motor warmed up it was fine
  21. #46
    Nov 2002
    80w90 is wayyy too thick man thats heavy gear oil. I think syncromesh is approximatley 10w-40 ish thick, but it might be like 20w50 weight... i cant remember, its not gear oil thick though
  22. #47
    Banned
    89 Honda LX
    Beertown, USA
    Thick oil would hurt your MPG I would imagine.
  23. #48
    Feb 2005
    1989 LXi Coupe
    Dallas Tx
    Holy crap...
    My car was grinding into third pretty bad, and grinding on a lot of downshifts.
    I just drained all of my old oil out and filled it with synchromesh (i found out penzoil makes the gm stuff, so i went with penzoild ebacuase it costs about half)
    Leme say, its like having a new tranny compared to how it was.
    The shifter 'clicks' into gears like a new car.
    I love it.
  24. #49
    Nov 2002
    yeah, but its not the friction modified version. They say the gm friction modified version is a bit better. But see, this shit works. 89accordresto was banned? I knew he liked to start shit but what did he get banned for?
  25. #50
    I dont know, but I looked through his last post and I dont see anything wrong. I know he useally says the wrong thing and talkes alot of smack about alot of people. Maybe it is coming back on him now .
  1. Syncromesh
    By 88accordlxcarb in forum Classic Honda Community Chat
    Last Post: 06-15-2007, 12:17 PM
