Hello all,
I am new to the board and I have found lots of good info...but I have a problem and need advice.
I have a 1989 Accord with a 2bbl carb...on the intake manifood there is a 2 inch aluminum pipe that sticks out...you normally connect hose to it (antifreeze circulation). The problem is that the pipe has rusted out and leaked to the point I was able to pull it out. Everywhere I go to try and find this pipe they don't have it. The pipe is pressed in at the factory. Will I have to find another intake manifold? I am not looking forward to installing the carb and all those vacuum line. Any advice?
Thanks,
R (Newbie)
