Results 1 to 9 of 9
Thread: removing pedal assembly
    ok i think i've got it figured out,but i want to make sure there is nothing wierd i'm going to run into when i remove the pedals. it's been a long time since i removed that set from the lxi. i know the four bolts have to come out,the cables have to be disconnected,electrical connections at the brake and clutch switch,fuse box because the one bolt is attached to it. i can't remember if i had to lower the colum or not. i think i rotated the others over it. I've had these pedals made for years now, and it's about time to install them. then i'll have cruise too. anyone else know anything else i'm forgetting?
    Jun 2005
    1986 Honda Accord POS tranny
    Edmonton AB
    im kinda interested in finding out too since im doing a 5 speed swap and need to put the pedals in soon
    Quote Originally Posted by newaccorddriver
    I can give you one tip, rebuild the 5 speed pedals before you instal them, if you can get all new bushings and stuff,they tend to get worn out over the years. I even powdercoated mine.
    you have to drop the steering column to get them off, take your time and move things that are in your way
    Jun 2005
    Edmonton AB
    is it easy to drop the steering column? im assuming its just a few screws holding it up, but i could be wrong
    Jun 2005
    Edmonton AB
    i wasnt aware you can rebuild the pedal assembly...
    89T's Avatar
    Apr 2004
    If you want to make it easy on you'r self remove all the pedal's mount the plate then reinstall the pedals.
    no need to fool with the steering column.
    if you do it right it will take half the time this way.
    my $0.02
    there are bushings and things in there that wear out, i'm not sure if they are available from the dealer, i made mine from urthane and machined them, it took a long time, they should last another 260000 miles.
    Quote Originally Posted by 89turbo'ed?
    my $0.02
    it's hard enough to get the springs and stuff right with them on the bench i def don't want to screw with that under the dash. they have to be right,if they aren't you could have problems with your brakes and stuff.
  1. shift assembly
    By ridered9hbs in forum 3geez Accords
    Last Post: 02-16-2006, 03:45 PM
  2. how do i take off the headlight assembly?
    By dj mackee in forum Interior & Exterior Care
    Last Post: 07-31-2005, 05:29 PM
  3. Hub Assembly Question
    By meangreenLXi in forum Suspension/Wheels/Tires/Brakes
    Last Post: 06-29-2005, 01:11 AM
  4. Broken pedal assembly.
    By pendejo in forum 3geez Accords
    Last Post: 02-28-2005, 02:06 PM
  5. WTB:5 Speed Pedal Assembly
    By 86dxAccord in forum Trading Post
    Last Post: 11-23-2003, 12:31 PM
