Results 1 to 16 of 16
Thread: what is a dual stage intake manifold?
    Jun 2005
    1986 Honda Accord POS tranny
    Edmonton AB
    i know there is a dual stage intake manifold in the 88-89 accords, but whats the difference between that and the one on my 86 accord?
    You have a single stage, meaning the Runner Length (The length of the intake tubing from the plenum to the cylinderhead) is the same all the time.
    The dual stage intake manifold has 2 sets of Runners, one set is shorter then the other. The extra set of runners is closed untill a certain rpm, then they open to give a shorter runner length.
    Jun 2005
    Edmonton AB
    is the dual stage one electronically controlled or something? i wouldnt mind adding it to my car, but i have a feeling the higher compression in the 88-89 have a little thing to do with the extra hp
    maka_RTH's Avatar
    Nov 2001
    '95 Supra, '08 CBR 600RR, '89 LX-i Coupe (R.I.P.), '88 LX-i Sedan (R.I.P.), '87 LX-i Sedan (R.I.P.)
    Orem, Utah
    it's vacuum controlled.
    Greg
    1989 LX-i 2dr 5spd (R.I.P.)
    2008 CBR 600RR -- 1995 Toyota Supra NA -- 2013 Nissan Frontier Pro-4x
    It is electronicly controlled in that the solenoid is electric.
    The solenoid is what holds the vacuum in the vacuum chamber untill it gets the signal to open and bleed the vacuum. When the vacuum bleeds the second stage diaphragm that uses vacuum to hold the secondaries closed, will begin to open because the vacuum is weaker then the spring on the diaphragm.
    The spring opens the second stage, the vacuum holds it closed, and the solenoid controls the vacuum stored in the cannister, the more vacuum in the cannister the stronger the vacuum, the stronger the vacuum the harder it is for the spring to open the second stage.
    You will need intake manifold from the 88-89 EFI accord ( A20A3 )
    If you want electronic control of your secondaries then take a look at this thread.
    https://www.3geez.com/showthread.php?t=46115
    2.0Si User Elijah's Avatar
    A20A3T
    Edmonton, Ab, Canada
    I have my old one you can have if you want. I will give it to you next time I see you or at a meet or something. I think its a mod not worth doing though. If your gonna change the intake mani just get a B16 one.
    Jun 2005
    Edmonton AB
    Quote Originally Posted by Elijah
    im currently having some trouble removing the auto tranny, so im going to start on some interior work until i can figure out what to do. im going to try and get a B16 manifold, but the problem is im not old enough to order off ebay... and i dont have a credit card yet... 2 more months and i dont have to sit through and watch those low priced auctions go by...
    1988 honda accord lxi sedan, 90 pontiac sunbird,
    colrado springs co.
    Quote Originally Posted by newaccorddriver
    just remember the shift cable dont come out of the trans,and then you have to pull the motor too, all in one shot.oh, yeah, dont for get the torque converter bolts, they suck when the trany is alraedy in.
    Jun 2005
    Edmonton AB
    Quote Originally Posted by baby D
    its apart, i just cant find enough room to drop it, and its too heavy to lift
    Jun 2005
    Edmonton AB
    what do the B16 intakes come from? just the civic SiR's?
    Busted_Blue's Avatar
    Jul 2003
    93 civic
    San Francisco, CA
    same as b18c5 or b16a.
    integra type r manifolds, or b16a powered cars.
    skunk2 makes a good copycat as well as blox.
    Jun 2005
    Edmonton AB
    those 2 sound pretty expensive
    snoopyloopy's Avatar
    Killa Cali
    blox's on ebay are going for about $170, and skunk2's are about $230.
    SEi User myaccord7's Avatar
    89 honda accord LX
    Quincy,IL
    so are they kinda like an old school vtec?
    zach
    Well variable runner lengths have been around for a while, vtec and secondary runners both try to widen the powerband in their own fashion.
  1. Replies: 0
    Last Post: 08-27-2011, 02:44 PM
  2. Single to Dual stage intake swap?
    By ahbeyra in forum 3geez Accords
    Last Post: 07-15-2004, 07:42 PM
  3. Which models get dual-stage intake?
    By Einstein in forum 3geez Accords
    Last Post: 03-31-2003, 08:17 PM
  4. dual stage intake
    By azaccord in forum Performance
    Last Post: 02-13-2003, 12:40 AM
  5. dual carb manifold
    By mykwikcoupe in forum General Engine Swaps
    Last Post: 02-07-2003, 10:26 AM
