i got an air/fuel gauge recently to try to help in the tuning of my carb...and have a few quick questions
i read somewhere that you can simply snip the 02 sensor wire and hook it up to the gauge because technically our motors only use the 02 sensor for emissions, is this correct?
speaking of which, is there only 1 sensor on the whole exhaust system?
located on the header? i expected there to be another one on, or near the catalytic converter.
i spliced in the wire after the small clip connecter on the 02 sensor going to the header as this was the only one i found, and in the instructions it said to do it like this.
it lights up and everthing but reads a real sluggish response on the gauge, it says im extremely lean when i know as of right now it is the exact opposite.
should i snip the 02 sensor and directly connect?
is there another wire i need to hook it up too?
just want this thing to read a semi-accurate response, instead of being a cheesy light-show.
thanks guys
