Results 1 to 4 of 4
Thread: torque specs for radius rod?
    Jun 2005
    1986 Honda Accord POS tranny
    Edmonton AB
    what are the torque specs for the radius rods? the manual i downloaded wasnt clear, cant see if its 40ftlb or not(pictures not accurate)
    Feb 2004
    89 accord lxi
    down by the bay
    the bolts are 40ft/lbs. the nut that holds the bushings in is 32ft/lbs, and the locknut on the adjuster is 58ft/lbs.
    Jun 2005
    Edmonton AB
    Quote Originally Posted by Strugglebucket
    how would i go about torquing the locknut?(i havent seen it yet but im assuming it just a nut that holds it in place by preventing it from spinning)
    Feb 2004
    89 accord lxi
    down by the bay
    you only need to torque it if you loosen it to adjust the length of the rod (to adjust your camber). the adjuster is basically an elongated nut so you hold that with a wrench while you tighten the locknut. come to think of it, you can't get to it with a torque wrench so the 58 is kind of pointless (it just needs to be tight).
  1. Ek1 bolts torque specs
    By eduardo i. in forum 1geez Tech & Performance
    Last Post: 08-17-2009, 12:50 PM
  2. 1986-1989 Honda Accord USDM HP, Torque, & Weight Specs
    By forrest89sei in forum Classic Honda Community Chat
    Last Post: 06-04-2007, 08:07 PM
  3. torque specs
    Last Post: 01-30-2006, 03:12 PM
  4. Torque Specs on Rear Upper Control Arm
    By mossimo817 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 10-18-2004, 02:37 PM
  5. Torque specs
    By 98hp in forum 3geez Accords
    Last Post: 06-09-2003, 11:34 PM
