Results 1 to 6 of 6
Thread: CV joint
    May 2004
    87 LX // 89 LX-i
    Cleveland, OH
    CV joint
    I think I have a bad driver-side CV joint. I hear a loud clicking noise whenever I'm cornering. The weird thing is that I only hear it when i accelerate in a turn. If i just coast through it without giving any gas it won't click. Wanted to see if that was something explainable or just a weird anomaly
    LX User cardoc33's Avatar
    88 accord lxi hatchback
    sf bay area
    It's your CV alright, boot's probably torn, spewing grease. you will need to replace the axle to get rid of the noise. Make sure to check the other side, too. If the boot's torn, but no noise, you can get away with just replacing the boot.
    Best Price on Clutch Repair in the Tri-Valley
    http://www.trivalleyclutch.com/3gparts
    OEM quality parts for your 3Gee
    LX User Ace's Avatar
    1992 Honda Accord EX
    North Smithfield R.I
    yea dude defintally the cv joint just went through that LOL
    "Id Rather Be Blown Than Injected"
    DX User 89AccordLX2dr's Avatar
    Oct 2003
    89 Accord LX 2dr, 91 Park Ave Ultra
    Ontario, Canada
    The majority of a C/Vs life is done driving in a straight line, thus the wear and tear is in the general area of the slight turns and straightaways. When they become so worn, they'll make a click sound when out of that area when turning at sharper degrees with force driving them into and out of the worn areas. When you turn sharp with load on the C/V you hear the clicking because of the force rubbing across the worn area, when coasting, the load isin't there as it just floats across that area. Eventually it'll wear so much that'll it'll stop forcing through the rough spot and just bind and snap. And it being worn, it'll wear faster and faster exponentially. It'll last if you take the sharp corners easy, but eventually one day it'll go snap. I've been driving on a bad c/v for about a year now, I just don't give er in tight corners, push the clutch in and coast them. I'll change it out someday. :|
    89 Accord LX 2dr Coupe - 240k
    May 2004
    87 LX // 89 LX-i
    Cleveland, OH
    yeah it looks like the last owner put a new boot on without replacing the axle. Freakin jerk. Thanks for the info guys. I've done the half shaft before on my old camry. If it doesn't come right out its a pain the the ass. I had to fab up a bracket so that I could hammer it off.
    sf bay area
    Don't worry, should just pop right out. Hondas are easy that way. Toyota axles are much tighter, and can be a real pain if not done right.
  1. Help ID 3 way joint...
    By 1989accordaz in forum 3geez Accords
    Last Post: 02-09-2011, 05:20 PM
  2. cv joint
    By Nio in forum Suspension/Wheels/Tires/Brakes
    Last Post: 03-06-2010, 04:05 AM
  3. Ball Joint...foiled by an effing ball joint...
    By Tailfin in forum Suspension/Wheels/Tires/Brakes
    Last Post: 12-21-2006, 11:40 PM
  4. CV joint fun!
    By imeside in forum 3geez Accords
    Last Post: 05-20-2003, 08:56 PM
  5. A Bad CV Joint?
    By Veedubya in forum Performance
    Last Post: 03-02-2003, 07:27 PM
