Results 1 to 25 of 41
Thread: What is the EASIEST way to wire up a vtec b series..b series guys tell me please
    SEi User
    south dakota
    I want to know the easiest way to wire up a vtec engine with obd1. I plan on using the hondata s300 with my new setup. A guy who makes conversion harnesses told me it would be easiest to attach the the b series connectors to the a20 harness, and add the necessary wires, but I was thinking it might be easier to just use the obd1 b16 harness and alter the plugs in the bay..I don't know. Either way, I know I would have to change the plugs at the ecu, either with a conversion harness, ($150)by switching pins, (possible?) or soldering all of the wires, (f that).
    I know several of you guys have b16s, etc, how exactly did you do it?
    Thanks
    89 coupe/ 06 TL 6spd
    Vancity
    you just add another wire on your harner for vtec..
    but i dunno if you can use your existing harness..cuz i went from a b18a-b16..yopu are going from a20-b16..so i'm not sure if the a20 harness can be used..and the ecu is totally different..so you need ecu as well..
    R.I.P Spoon Se-i 01/17/04
    SteveDX89's Avatar
    2002 Mazda Protege5
    New Freedom, PA
    I would take the B16 harness and switch the bay plugs. Namely, the 2 large round ones on the driver side and the 1 rectangular one on the pass. side. Basically, I'm saying if you take you're B16 engine harness. Pull the plugs off that plug into the car's cabin harness and put the Accord plugs on them. Then whatever doesn't fit in a plug (VTEC, knock sensor, etc.), you can make that a subharness and run those wires right to the ECU. You can try swapping the pins around at the ECU instead of using the conversion harness but I've looked into it and it looks pretty difficult. It might be worth it for the conversion harness. I've seen them for $100.
    SEi User
    south dakota
    Thanks steveDX89, so you just modified your b16 engine harness to fit the accord plugs and added wires? do you have an obd-1 ecu?
    Damn..this is going to be such a fucking pain in the ass, it'll probably take me days to figure out.
    bobafett's Avatar
    Stock 86 Accord LXi Hatch
    Longview, WA
    www.boomslang.com ? .org .net maybe?
    www.jkobd.com
    save yourself the hassle...
    SteveDX89's Avatar
    2002 Mazda Protege5
    New Freedom, PA
    PRI made my harness but that's all they do. If I had to do it over again, I would have done it myself and saved the $350. My car is still OBD 0.
    SEi User
    south dakota
    I just hit up jkobd.com, we'll see what they can do..Boomslang wasn't very helpful, they wanted me to do most of it myself and just plug in their little adapter harness at the ecu. Most of the work would be in the engine bay, and that's what I Would like to avoid.
    Quote Originally Posted by Accordtheory
    I had my a20 engine harness converted to an obd1 ls/vtec harness by rywire and Jkob made my sub harness. The two companies worked together to make the whole wireing system work. I would recomend bolth companies they did a great job on the sub and engine harnesses.
    SEi User
    south dakota
    cool, I just emailed rywire too, thats what jkobd said they would do. How much did it end up costing you?
    I am not going to disclose that, because mine will be a test harness, but I will tell you I got out for under $350.00 for both harnesses witch is a damn good deal. I sent rywire a harness from a junkyard car. I will let everybody know how it works out when I install the motors.
    SEi User
    south dakota
    Well, it'd going to cost me more than that.. I don't have a legit a20 or vtec harness yet.
    hey, do you have a pic of your completed harness by any chance?
    thats the best I can do, If you notice the wires coming out of the ECU that connect to the harness. Those are the wires that our harness dosent have.
    SEi User
    south dakota
    thanks for posting the pics..how long do you think it will be when you have everything set up?
    about a month or so depending on school and work . I will keep you guys up to date.
    SEi User
    south dakota
    Re: What is the EASIEST way to wire up a vtec b series..b series guys tell me please
    I just talked to a guy at rywire (I don't know if he was ryan or peter) today, and he said I could send him the necessary connectors from the obd-1 harness, not necessarily the whole harness, which is cool, because that saves me like a $100..I should be sending the shit out to them pretty soon. One thing I asked about was the vehicle speed sensor, I guess you need that signal to the ecu to activate vtec, I highly doubt the accord has that, I don't know. I can probably disable that with the ecu program. Hopefully it will all turn out legit..but I'm not that worried because I know if it came down to it, I could wire the whole thing up myself.
    hey legend master, what ecu are you going to use? p28?
    That spunds good, and yes I am running a chipped p28 for an LS/vtec and it had a couple of goodies in it.
    SEi User
    south dakota
    What was the turnaround time for rywire to make the harness? I forgot to ask..
    it took awhile for me because I was the first, but now he has the diagram so he can do it rather quick.
    SteveDX89's Avatar
    2002 Mazda Protege5
    New Freedom, PA
    Our cars have a VSS and the signal does go to the ECU. The speedo cable drives the speedometer but there's also some electronic do-dad that runs to the ECU from the gauge cluster. My ECU is not chipped and VTEC works just fine.
    SEi User
    south dakota
    just sent my shit off to rywire today..those guys are going to be off at sema, but when they get back, 2-3 weeks it should be done..cost will be around $310..
    SEi User
    south dakota
    Well, I just got my harness back from rywire today, and the damn thing won't fit! uugghhh....The wires extending from the main harness to the ecu jumper come out of the wrong end of the harness, at the left front of the engine bay. There is no way they will reach all the way to under the driver's seat! damn it.. Hopefully this will be fixed soon. I thought about connecting the harness extension to the wires at the control box, and then splicing those into the ecu jumper, but only 7 of them go to the ecu and I need 10.
    Damn that sucks, make sure to let him know the problem. I bet he can make and extention harness that will take care of the job.
    SEi User
    south dakota
    Where do the wires going to the ecu jumper come out on your setup?
    I dont quit understand what you are asking. If you mean what the wires are for they are for all the parts of the OBD-1 harness that are not located on the accord Harness. If you mean physically, it has not been installed yet so I couldent even tell you.
    SEi User
    south dakota
    You only need to glance at your harness to understand what I mean. The wires that have been added exit the harness and run directly to the 0bd-0-obd-1 conversion jumper harness at the ecu. Where on the accord harness does that little bundle of wires exit? There are 3 main connectors on the accord harness, 2 up by the right shock tower (not counting the resistor box) and 1 at the front, behind and a little to the driver's side of the passenger side headlight. Those guys have never seen a 3g engine bay, because the subharness wires exit at That connector, at the front of the engine bay! Then they have to travel back from there all the way to under the driver's seat, where the ecu is? No way..
    I still think those guys are legit though, I just hope they'll fix this shit..
    That little subharness of added wires should exit the main harness a little to the passenger side of the alternator, have a connector right there so you could disconnect it when you want to pull the engine, and then go straight back through the firewall to the ecu. That would allow for the shortest wires, and it would just be the best, easiest way to do it.
  1. easiest way to wire N/A JDM B20A
    By mykwikcoupe in forum JDM B18A / B20A Swap Tech
    Last Post: 05-01-2009, 02:19 PM
  2. DOHC VTEC B series Stuff For SALE!!
    By 87ludeITR in forum Performance
    Last Post: 05-03-2008, 02:31 PM
  3. 86 BS series help
    By Nospeed in forum 3geez Accords
    Last Post: 08-17-2005, 09:04 PM
  4. how to wire vtec
    By johnypimpin2005 in forum General Engine Swaps
    Last Post: 01-02-2005, 10:03 AM
  5. Spoon B-series performace for A-series
    By A20A1 in forum Performance
    Last Post: 01-19-2003, 08:26 PM
