ok i have found a way to retain the hot air function for the carb in the winter,what i am doing is mounting a small transmission oil cooler under the scoop,this will have coolant that flows through it to heat the air that is going into the filter,this coolant will be controlled by a vaccume operated water valve i need to source from the junkyard. i have retained my hot air door controls in my new intake system. instead of them operating the air door they will operate the coolant water valve and regulate air intake temp just like before. this system is able to be switched by a solonoid valve i have installed and will be controlled by a switch. that way it can be shut down when i want.
cooler mocked up
the temp bleed vaccume switch was retained on my new intake system
the vaccume control valve i mounted up under the cruise control unit
