Ok im usually on the forums for help with my 87Lx which is out of service right now with a dead alternator, so right now im using my old 88lx to get around. The 88 has been sittin around for about 2-3 months unused when i got the 87 and the waterpump went out on it i think from sittin around without bein started often enough. The car worked but i needed to keep the coolant in the car it leaks from the water pump pretty bad. I havent been driving it far, keepin it within a 5mile radius from my house. Today was a hot day and the car did the usual overheating went to the "H" on the guage and i would find a spot to stop and let it cool off. I was on my way home and it was started to get hot again and then began to die at stoplights and signs. I had to crank it a good min. and give it some gas to get it back on again. Before when it started dying at stops when the car would get hot i started to make a rattling sound from under the hood. Sounds like a nut or an empty coke can gettin knocked around in my engine. Rattle is constant and only when accelerating. The noise got louder and louder as i got closer to my house. When i got to the house the car was smoking and could hear all the gurgling that come with overheating but i also smelled somethin else that smelled like burned oil or some other fluid that wasnt antifreeze. Im not that worried about this car because i dont plan to keep it after i get the 87 fixed. Which is why i've been stupidly driving the car around with a bad water pump. But i still want to know about this knock/rattle sound because my 87 does it to but not so loud u have to listen for it on the 87. I think its heat related because when i 1st started hearing it from the 88 it would come and go usually it would stop after putting some coolant in. The 87 has always done it since i got the car hasnt gotten louder or gone away and i havent had overheating problems from it. I opened the radiator up and it was full so i dont know what the cause is. I dont think i blew the head gasket on the 88 yet becuase i havent seen any white smoke from the tail pipe. I anybody could shed some light on this i would appreciate it, thanx.......![]()
