Results 1 to 7 of 7
Thread: tranny wont line up...
    Jul 2005
    1987/honda/accord LX 1988/honda/accord lx-i 5spd/1990 accord ex auto
    scranton,pa
    well today i took out the old clutch and put the new clutch and everything in (still using old pressure plate and throw out bearing they werew brand new a few months ago and show no wear)... so everything was aligned and i lifted the tranny and tryed to guide it in and everytime it was a no go... so i was wondering if when i took the shifter linkage off i put it into gear and it wont go in. would that stop the tranny from going into the clutch...
    thanx spanky.
    SEi User
    Jun 2005
    1986 Honda Accord POS tranny
    Edmonton AB
    im having the exact same problem lining up the transmission with the engine. im going to try and get ahold of a transmission jack. just like every other clutch change, aligning the transmission is probably the hardest part of it all. if my friend wasnt such an ass and actually showed up, it would be in by now. and id be on my way to finishing the swap
    SEi User MattsAccord's Avatar
    Feb 2003
    1986 Honda Accord LX
    Southern Oregon, Medford
    Yep that is the worst part of changing clutches. Good luck it will go in.
    Feb 2004
    89 accord lxi
    down by the bay
    just keep at it you'll get it. be glad it's not a 4th gen, ugh.
    make sure the dowels are lined up. sometimes the ground cable for the starter can be in the way and you won't realize it. oh, and put some grease on the shaft splines to help it get in the pressure plate.
    no.
    Jul 2005
    scranton,pa
    yea, it is the hardest part. i can tell you now if the clutch ever goes again im gonna have a mechanic do it so i dont have to bust my nuts trying to put it in.
    SteveDX89's Avatar
    2002 Mazda Protege5
    New Freedom, PA
    Quote Originally Posted by spanky
    I'd rather save the $200 - $300 in labor.
    Vinny's Avatar
    Aug 2003
    Here, not there
    not like 3 hours to do it all is alot of time, atleast that what it takes me
    If by not lining up you mean you cant get the splines lined up?
    Did you use a clutch alignment tool when you put everything together?
    Have you tried to turn the input shaft on the transmission then tried to restab it?
  1. Replies: 7
    Last Post: 07-16-2011, 07:16 PM
  2. timeing belt wont line up, please help!
    By labeledsk8r in forum 3geez Accords
    Last Post: 10-30-2006, 03:59 AM
  3. auto tranny cooling line?
    By 1987HondaAccord in forum 3geez Accords
    Last Post: 11-24-2004, 02:05 AM
  4. Changed A Hose, Found Tranny Fluid Line?
    By HondaBoy in forum 3geez Accords
    Last Post: 10-23-2004, 06:41 PM
  5. Replies: 3
    Last Post: 06-17-2003, 04:54 PM
