drill a hole in the bottom so it can leak out
you mean like in a rowboat?then it might sinkyou better fix that leak quick or your next mod will be fish
Rice & fish......hmmm. Add a little wasabe and enjoy! A syringe and a good blast of water through the tube usally works on most blockages. You can get big ones at Tractor Supply or feed places if you have those around. Anyplace that deals with farm animals and supplies really. But I'm in Kansas so....good luck. Stray away from the compressed air though, screws up the drain tubes and makes them leak if the blockage doesn't exit quickly enough.
W.T.F?
oh didn't drive it to fla. needs headgasket... was under the tarp for all of the 9 days dry as a bone on returnanyways um no i won't be drilling any holes.
Yikles, cold water down my neck! Parked with it facing uphill in the driveway, and when I backed her out, i got woke up quick? Anybody have a good tip for cleanign out the rear drain holes? i think i have to remove the headliner. Thx.
i used kitchen and bath caulk on my tail lights with the old gaskets worked like a charm.
and its a latex based product so no volitile reactions to metal.
pic's of project at my homepage: home.earthlink.net/~andyk65
try a long piece of wire or a air hose with a long thin piece of copper on a air chuck so you can reach in there.
https://www.3geez.com/showthread.php?...ight=moon+roof
had the answer to the "leaking" moonroof problem. clogged drain tips. a lot of water came out, but not as much as went down my neck and my crotch today when I left work, after an all day seatle rain. Will see in thenext couple days if there is a clog in the top of the inlet to the drain tubes.
What a great search engine and bunch of contributors this board has.
Okay so the guy at one body shop so far has said it'll be $300 to be welded shut...should it be that much???
