Results 1 to 3 of 3
Thread: alt-charging/not charging
    1989 4 door SEi 5spd, 1989 4dr SEi auto, 1989 SEi coupe 5spd, 1988 LXi H/B auto (kids car), 1987 LX 5 spd (other kids car), 1988 Civic 3dr
    montana
    my 88 accord alt is possibly on the fritz?
    Voltage with car off is about 12.5v
    when I start it - voltage stays at 12.5v or so, and seems that it won't start charging until I turn on lights or fan, etc - at that point the idle comes up a bit and volt meter shows 14.5v. If I just let it idle - eventually it will start charging at 14.5v, but seems to take couple minutes....
    I pulled alt and replaced brushes (they were shorter than spec). Re-installed alt and no changes - still does the same thing.
    What could be the problem? This is the second set of brushes on this alt. (289,000 miles)
    thanks
    probably the voltage regulator is bad or isn't getting the signal from the ignition II position.
    Eric
    montana
    Re: alt-charging/not charging
    Thanks for the reply - I haven't worked on it yet - car is still doing the same thing so it hasn't been a problem. I'll let you know what i come up with.
    Anyone else had a similar wxperience with an alt not charging until a load is put to it?
    thanks
  1. Replies: 40
    Last Post: 02-13-2017, 06:16 PM
  2. 2 new alternators still not charging, HELP
    By zander4am in forum 3geez Accords
    Last Post: 03-23-2010, 04:19 PM
  3. Ashtray charging hub
    By canadian357 in forum Interior & Exterior Care
    Last Post: 06-08-2009, 06:41 PM
  4. Charging system HELP!
    By Ajbent86 in forum 3geez Accords
    Last Post: 09-02-2008, 01:50 PM
  5. Alternator not charging..??
    By ChaseR in forum 3geez Accords
    Last Post: 03-02-2008, 07:23 AM
