Results 1 to 6 of 6
Thread: Engine Troubles
    DX User Phi.Rus's Avatar
    1989 Accord DX
    Canaan, CT
    Engine Troubles
    I have a 89 Accord DX, carb. I am having some not so slight engine issues... First off, it sounds like a lawn mower, which i have narrowed down to 3 things. Mechanic says there is a possibility that the distributer is dead...or gone...or dying...w/e. Another is a exhuast leak (interesting side note, i bought a replacement exhuast piece, and the bolt pattern on the engine end, not the cat end, was backwards....strange) And lastly, a possible dead cyclinder. The OTHER issue is that is smokes worse than a backed up wood stove, thick white/blueish smoke (which could be related to the engine...malfunctions?) would be cool if i could track down some answers. Thanks guys. (p.s. its at 199,856 miles, cant wait to see that barrier broken)
    1ajs's Avatar
    slurpeepeg
    the smoking can be cause bye your piston rings or your valave seals haveing same prob but its are piston rings but are engin is on borowed time if you knew what we have done with are 3gee you would be amazed and would have great respect for these cars. the recors aka bucks has become are best source for parts in the last few years here in teh peg
    but its most likly your valve seals its a flaw with these cars also the gth gear on these cars were out
    you say like a lawn mower defenitly your exaust
    million k 3gee
    1ajs's Avatar
    slurpeepeg
    arrrg it glitched out
    1ajs's Avatar
    slurpeepeg
    arrrg it duble triple posted lol silly glitches
    I think you could have an over-rich condition or sticking valves, do a compression check
    1989 Accord DX
    Canaan, CT
    Re: Engine Troubles
    Thank you for the help. Awesome.
  1. Hub troubles!!
    By Oregons finest in forum Suspension/Wheels/Tires/Brakes
    Last Post: 06-11-2011, 08:08 PM
  2. 88 accord carbed engine troubles
    By JordanQ in forum Carburetor Tech
    Last Post: 04-08-2009, 07:46 PM
  3. ***car Troubles Help!!!!***
    By 89AccordLXI666 in forum EFI Tech
    Last Post: 08-14-2004, 01:06 PM
  4. Engine Troubles
    By James in forum 3geez Accords
    Last Post: 09-08-2003, 04:42 AM
  5. Troubles with the car
    By rob49 in forum 3geez Accords
    Last Post: 02-09-2003, 02:53 PM
