Results 1 to 4 of 4
Thread: Radiator hose tip
    AZmike's Avatar
    Jul 2002
    Tucson, Arizona
    Radiator hose tip
    When removing radiator hoses be very careful. I ended up with the old, brittle plastic fitting for the lower radiator hose stuck in the old hose when I "removed" it. I had to replace the whole radiator because I wasn't careful ($65 after 4 hours of driving across town).
    Just thought it would be a good idea to remind everyone else to be gentle (or slice that old hose off). No sense in anyone else screwing up like this.
    Mike
    Vanilla Sky's Avatar
    1999 Penalty Box
    i feel you man... even with the connectors are metal, you gotta be careful... i messed up a brand new AC condenser by not being super carefull (it's repairable, but still...)
    Derick
    AZmike's Avatar
    Jul 2002
    Tucson, Arizona
    The upper and lower radiator connections to the Toyo radiator I had were plastic.
    Mike
    1987 Accord Lx - automatic-carb
    There's been alot of talk about this at another car site - european. Some believe that using a very low phosphate coolant helps reduce wear on the plastic necks. Other dismiss it as bunk. I personally believe that overtightening of the clamps is the biggest problem.
    One pro mechanic at a Mercedes site said that he snugs down the hose clamps to where he believe it's fairly snug, then hooks up a cooling system pressure tester to the radiator. He then observes any and every point under the hood(primarily hose connection) where coolant can leak; then gradually tightens any spot where coolant is seeping from.
    The idea here is to prevent overtightening of the clamps.
    Lester
  1. radiator hose
    By teck in forum 3geez Accords
    Last Post: 06-20-2007, 07:03 PM
  2. Lower Radiator Hose B-swap
    By Legend_master in forum General Engine Swaps
    Last Post: 01-28-2006, 01:22 PM
  3. radiator hose temps
    By danronian in forum 3geez Accords
    Last Post: 09-24-2003, 10:00 AM
  4. A slight problem with a small radiator hose
    By 89AccordLXI666 in forum Carburetor Tech
    Last Post: 05-12-2003, 08:40 AM
  5. radiator hose goes BOOM whenit breaks!
    By HondaManDan in forum 3geez Accords
    Last Post: 08-03-2002, 07:03 PM
