ok the cigarette lighter just doesnt work
check all your fuses....and make sure the wire is attached in the back.
-Aaron-
could be the lighter itself, if it's used often... but check everything else first... if you need a new socket, i have one, just pay shipping
Derick
First thing to check is the 15 amp (blue) fuse in the underhood fuse box.
um sorry dude but theres like 5 15 amp fuses in the under fuse box...unles you meant the #15 fuse which is the RR Power window and its 20 amp...
You have the same year and model that I do. There is a 15 amp fuse in the box under the hood that says it is for the clock and lighter. If your clock is working then that is probably not the problem.
ok so i checked all the fuses and no luck... whut else can i check?
is it hard to replace cuz i have a parts car...
I have an 88 Accord LX-i with the same problem, pretty sure its the socket. How much for the socket shipped Vanilla Sky?
