Hey. Last night, on my way home from getting some food, my car decided it didnt want to idle at all. It ran fine, but everytime I got down to about 30, the car would drop to about 500 RPM's and then at a complete stop, it would sputter and stall. Normally, if this ever happened, it would start right back up, and it didnt, I put my foot to the floor to activate the choke, and it still wouldnt start. I then put my foot to the floor and held it there, after about 15 seconds, it started up, i kept my foot on the floor and held it there, it took 10 seconds to get up to 1000 RPM's and then from there would go all the way up into 4000, after i let up, it stalled again, and then the same problems. This morning I attempted to start the car and it turned over once and then the starter locked. If I hold the starter, the starter will move, and then the car will start, but for a brief amount of time, and then it will stall. This problem happened when I first got the car, and then cleared up and worked perfectly from June until now. Is it a fuel filter, fuel pump, vaccum leak? Could the change in the air temperature be the problem? I only wish this car was fuel injected, the I wouldnt have to worry about dropping some money on getting the carb rebuilt. ANY and ALL help is appreciated. Thanks.
-Brett
