Results 1 to 15 of 15
Thread: Need piston ring info
    SEi User racerx's Avatar
    May 2003
    87 Honda Accord DX
    Colorado Springs
    Arrow Need piston ring info
    Ok, I bought a set of "Sealed Power" piston rings for the engine. The top ring looks good and has a smooth edge, as does the oil rings.
    However, the middle ring is just a sharp edged rough ring. Is this normal? Is that meant to break in the engine? It feels like it would chew the crap out of the cylinder walls... Should I polish it or something? lol
    Thanks
    www.stein-photo.com
    born to XLR8
    south dakota
    Re: Need piston ring info
    Rings don't break in the walls, it's the other way around. The ring doesn't exactly match the wall due to it not remaining in a perfect circle as it fits the diameter of the cylinder. The surface texture of the wall wears the ring to the right shape. If you've chosen the right texture, the ring will be shaped correctly by the time the texture is gone. I haven't used sealed power rings, I only have experience with honda and wiseco, but I would be surprised to find their rings are half assed enough to cause cylinder damage..
    May 2003
    87 Honda Accord DX
    Colorado Springs
    right on. thanks for the info... i guess i just need to make sure i hone the walls right.
    www.stein-photo.com
    born to XLR8
    Mar 2005
    swifts/sprints boosted
    Saskatoon
    I dunno, but I would probably do that anyways :p
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    Basically deglazing or honing the cylinder walls with a 50 to 60 degree crosshatch pattern is what you need to seat the rings, regarless of the sharp edge on them. It is very critical in setting the proper end gap & spacing the rings accordingly. Last but least, wash the cylinder bores with hot soapy water real good, make sure your get all fine particals of shaving out before installing pistons w/ rings.
    May 2003
    87 Honda Accord DX
    Colorado Springs
    spacing the rings? I know how to do end gap, but what's this about?
    www.stein-photo.com
    born to XLR8
    Quote Originally Posted by racerx
    yeah dingle ball that baby
    south dakota
    i think what ddude2uc means by spacing is what some people refer to as clocking or staggering, etc, basically just make sure the end gaps are on opposite sides of the piston, so the air can't just flow straight down through all the gaps at once.
    May 2003
    87 Honda Accord DX
    Colorado Springs
    oh right. geez I almost forgot about that! (prolly would have remember though lol)
    but don't the rings spin a little in the motor?
    www.stein-photo.com
    born to XLR8
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    Yes, the piston rings do spin around the piston during motor operation. The spinning varies on compression in the cylinder, operating temperature & R.P.M.s
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    Opps, double post
    south dakota
    now I'm going to have to remember to pay attention to this next time I dissassemble an engine. If the rings are correctly staggered, then I'll conclude they don't move.. I know if they move at all, it sure isn't much. there are no rotational forces on them whatsoever, and the friction of them being compressed against the ring land by cylinder pressure would make it difficult for them to rotate even if there was a force trying to move them..
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    Yeah, I agree with you Accordtheory. If the rings spin any, it isn't much. I think they move about 1/2" either way. I've never seen a cylinder bore look like this from rings not moving.
    Sorce- http://www.sacskyranch.com/piston_ring_rotation.htm
    Sealed power rings. Just make sure the ring end gaps are within the right tolerences and also the bore to piston gap, and that you have the rings in the right way up, and also if thats all okay make sure that the vlave guides are all new with little slack and that all new seals are on them, as the engine will have much better suction after it's been built properly and blueprinted it will put added pressure on the valve guides and seals. Used Total seal rings once and the extra vacuum created sucked the oil down the guides like you wouldn't believe great for cylinder and valve lubrication bad if you don't like smoke coming out the back at idle!! Compression was awesome though 240 psi per cylinder!!! Stock is about 180-190 psi!! With good quality rings and a re-bore you should be able to hit at least 200-210psi.
    May 2003
    87 Honda Accord DX
    Colorado Springs
    hell yeah! i've got all new seals, and i'm gonna have the head milled about 0.030". should be good. maybe i'll save a little longer and have the head P&P.
    www.stein-photo.com
    born to XLR8
  1. piston ring installation
    Last Post: 04-08-2007, 11:17 PM
  2. JDM Dual Piston Brake Caliper Rebuild Info
    By 2ndGenGuy in forum Restoration & Custom Fabrication
    Last Post: 02-05-2007, 09:28 AM
  3. Piston ring install, rod & bearing clearance
    By 88Accord-DX in forum How To
    Last Post: 06-14-2005, 06:38 AM
  4. Piston landings???
    Last Post: 02-18-2004, 09:15 AM
  5. FS: A18 Piston Ring Set for a buck....White Box Parts
    By BootMachine in forum Trading Post
    Last Post: 01-30-2004, 08:47 AM
