Results 1 to 9 of 9
Thread: HELP!!!. Alternator/waterpump belt install?
    Jun 2005
    87 Honda Accord EXi/ 97 cavalier
    Sk
    Ok.. car died last night while GF was driving, Checked it this morning and found the water pump belt/alternator belt snapped.
    so i bought a replacement today but now i pop the hood and it looks more complicated then i expected..
    Question is there is one pulley that turns all three belts near the bottom (as pictured here)
    seeing that the alternator/ waterpump belt is the one on the inside, does that mean i would have to take off the other two belts to get the water pump belt on or is there a different way?
    if so can someone give me details instructions? as i can't find it in the manuals.. thanks!!
    87 Accord EXi Auto - Project car/ daily driver
    97 Cavalier (modded)
    Jun 2005
    Sk
    Re: HELP!!!. Alternator/waterpump belt install?
    btw, i own a 87 accord Exi with FI a20.
    1989 Honda Accord DX
    Oklahoma City, OK USA
    Hello Yanman,
    Yes, you'll need to remove the belts in front to get the belt on in the back. It's not really difficult - just tight quarters in which to work. Good luck!
    Jun 2005
    Sk
    yea i got the powersteering pump off no prob.. the a/c on the other hand is bs..
    i think i might just cut the belt seeing how that we don't use a/c anyways..
    Yanman,
    This is my first attempt to add a picture so please bear with me if this doesn't come through. Basically, it appears that there are four adjusting bolts for the AC compressor: two are behind the compressor and two are in front (see attempted image below). Unless you're just wanting to get rid of the AC compressor altogether, just follow steps 13 & 14 in the image.
    Here goes:
    The way I take off belts is with the engine running I'll put a long object (a torque wrench or tire iron or bat) near the moving belt and gently pushj it off, the engine will doo all the rest of the work for you.
    be careful!
    or you can spend an hour loosening all the adjusters and tightening them again :b
    and yes, the other belts have to come off. 1st is the power steering , 2nd is a/c, 3rd is water/alt (already gone). Installation is the reverse
    Eric
    SEi User
    Mar 2005
    swifts/sprints boosted
    Saskatoon
    be careful!
    Apr 2004
    88 LX, 17"x7.5" Enkei 205/40's, Custom fabbed Seamless body front to back, shaved trunk, waiting for 3-Stage Candy paint to be applied
    Canada
    A) REMOVE POWER STEERING BELT
    1) Loosen top Bolt 14mm (PWR Steering Pump)
    2) Loosen Lower Bolt 14mm (PWR STEERING PUMP)
    3) Push back Power Steering Pump
    4) Remove pwr steering belt off crank shaft pully
    B) REMOVE ALTERNATOR/WATER pump BELT
    Need To Jack up Left side of Car
    1) Loosen Alternator Bolt 14mm
    2) Back off Alternator Adjusting Nut 12mm
    3) From under the car find the Lower Alternator Nut
    and loosen
    4) Push Alternator Forward
    5) Remove Alternator Belt off crank shaft pully
    Very Simple Less then a Hour to remove and Install
    Lost my Signature...
    LX User Cant Stop's Avatar
    1989 honda accord lx ,2006 accord se 2.4l i-vtec 166 hp 5spd
    orlando florida
    ya i like it when i slip or the belt flys out taking everything in its path. NEVER EVER TAKE BELTS OFF WITH THE MOTOR RUNNING!!
    THIS METHOD COULD KILL YOU!!!!
    he was joking right?
  1. waterpump/alternator belt adjustments
    By drock in forum Classic Honda Community Chat
    Last Post: 01-16-2011, 02:42 PM
  2. Alternator belt
    By russiankid in forum 3geez Accords
    Last Post: 01-17-2007, 08:51 AM
  3. alternator belt ?
    By Tref_LXI in forum 3geez Accords
    Last Post: 08-06-2003, 08:55 AM
  4. Alternator belt install???
    By greekguy7 in forum 3geez Accords
    Last Post: 03-20-2003, 05:18 AM
  5. alternator belt
    By slammedLXI in forum 3geez Accords
    Last Post: 03-12-2003, 02:49 PM
