Results 1 to 3 of 3
Thread: Weird vacuum behaviour?
    LX User Soundy's Avatar
    A20A2 2bbl 5spd 1987 Accord LX hatchback
    Pitt Meadows, BC
    Been meaning to ask about this for a while...
    When I was checking the ignition timing on my A20A2, I pulled off the #2 vacuum advance hose as directed... the engine started sputtering and slowed to a crawl, as expected, and plugging the hose smoothed it out and brought the idle back up, though not to the same level it had been.
    HOWEVER... simply pinching off the hose with it still attached, which SHOULD have the same effect, instead has NO effect.
    With the hose attached, pinched or unpinched, the timing is at the 20-degree mark at about an 800rpm idle... with the hose disconnected and plugged, it drops to 650-700 and the timing mark is nowhere to be found, even with the distributor twisted to full-advance.
    The real question is, shouldn't pinching the hose off while still attached (and I mean, pinching it TIGHTLY with pliers) have the same overall effect as removing and plugging it???
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    Re: Weird vacuum behaviour?
    Well not really. Since vacuum is still trapped inside the advance diaphragm. Between the pliers and the distributor.
    If vacuum can't bleed off some how then pinching the hose wont have any effect.
    You can get a vacuum gauge hook up a "T" fitting for the gauge to tap into. Plase the "T" inbetween the distributor and the place you're going to pinch off.
    Check the gauge reading before and after you pinch.
    Pitt Meadows, BC
    Oooooooooof course.... d-oh! Makes perfect sense, thanks
  1. rpm's R weird
    By danny nr crew in forum 3geez Accords
    Last Post: 05-12-2009, 01:02 PM
  2. Vacuum Tank , vacuum hose
    By En-g in forum 3geez Accords
    Last Post: 09-06-2006, 04:32 PM
  3. weird?
    By bobsaccord in forum Suspension/Wheels/Tires/Brakes
    Last Post: 06-09-2004, 07:56 PM
  4. Strange behaviour when starting
    By petes_86lxi in forum 3geez Accords
    Last Post: 02-14-2004, 06:07 PM
  5. Weird!!!!!
    By thundertank in forum Performance
    Last Post: 08-07-2003, 02:07 PM
