why? lol its my dads car not mine though i wish it was loves this car
sprayed some of the zink oxide primer over the rust and painted over the primer as you can see here lol also you can see the door dented it from idoit over the years the green thing hangin out just clip for a meter.
front driver side this dent has been there for as long as i can rember there bit of fibor glas put in to seal the holes as it has rusted sprayed it with the zink oxide primer to stop it from rusting any more
congrats on the pos
what this aint no pos¿¿ if it was it would of died long time ago
can you put up a picture of the odometer?
that's pretty cool.
All Hail the immortal Accord...Hazzah!![]()
Originally Posted by sticks
I want to see this also. I only hope my accord lasts that long![]()
not the orig instrument panel on this car ...... had to replace it cause it well was worn out from geting wet... but all i must say that its mathimaticaly estimated at 1mil if you had read the orig thread i had in carb tech you would know this lol also if you did not know the speedo was brocken for 10 years you would know this from reading that thread as well.
just wish it did not smoke when it goes below zero ... pluging it in stops this from happening though seals on the head were replaced no macheaning done to it just ruber seals replaced
also the gunk you see on valves was on cylder 2 and 1 valve on cylder 3
intake valves only had this build up on this on thoughs cylders. no goudest in the cylder walls when we looked took some photos with 35mill cam should deveop thoughs i gues befor we had the digital
its had sythectic practicaly its hole life. the oil is changed every 10k been changed 3 times this year since the head was off tells ya anything
anyhow just some info
bonivill power you ride is mint you did well only thing that would kill it is if you get into an acendent just respect you 3gee and it will repsect you back it had an esay life
phrenology lol txs this car seems like it is after all it was submerged under 8ft of water in 93 and its not rusted out or dead. also the reson why the trany died that winter.
