It's time to service the brakes on my car, because it's been 10 years since the last time I did any brake maintenance except changing front brake pads. Today, I checked the brakes on the 4 wheels, the following are the current conditions:
Brake lines: No cracks or deterioration, only slightly rust on the mounting bolts.
Rear brakes Pads are still thick (it's been 10 years!), all the brake component are in very good condition.
Front brakes
- Brake Pads (2 years old): on both sides, the outer brake pad is 2mm thinner than the inner brake pad. but it still has at least 6mm pad material.
- Brake pad shims: all 4 are gone.
- Rotor: The rotor surface are very good on the inner side, but has obvious wear on the outer side. It has very slight grooves on the outer side surface. The total thickness is 17.9mm, it's about 1.1mm thinner than new rotors (19mm), 0.9mm thicker than the 17mm service limit specified by Honda.
Here are my questions:
- Brake fluid: The brake fluid is 10 years old. I plan to replace all the fluid in the system. The tool I have is a vacuum pump. I plan to suck out the brake fluids according to the bleeding sequence. Any problem with this solution?
- Brake shims: What's the use of them anyway? I've been without the shims for 2 years, and there seems to be no difference at all.
- Any other suggestions?
Thanks a bunch!
