Results 1 to 9 of 9
Thread: Which way do these springs go?
    SEi User Acid X's Avatar
    Apr 2005
    Azusa, CA - Los Ang. County
    http://img488.imageshack.us/my.php?i...502full6zt.jpg
    I bought them off of a guy here and he tells me the flat end goes up top (the end that can stand on its own). I've been told by other people that the larger gap in between springs goes up top. This would mean the flat end goes at the BOTTOM of the spring.
    Thing is, the front's fit best with the flat end at the top, while the rears are opposite. This means that in the front the tight end goes up top and in the rear the tight end goes at the bottom.
    Now, should i just mount them both with the flat end at the top, or should i do it the way people tell me and put the big gaps towards the top. OR should i just put it the way that seems to fit best?
    I dont have the part that attatches to the top of the wheel well to put at the top of the strut and test with the whole thing together...
    Advice would really be nice!
    90 CRX
    SEi User halxi's Avatar
    88 LX-i Coupe
    Brighton, Colorado
    Re: Which way do these springs go?
    your struts should be grooved/channeled/layerd/offset on the cup for the spring so it sits in there tight.
    The flat part (or tighter coiled part) always goes towards the top.
    Apr 2005
    For sure? The rears seem to sit better when its the flat part towards the bottom.
    90 CRX
    88 LX-i Coupe
    Brighton, Colorado
    100% positive.
    h/o let me get a pic resized of my tockico with my intrax spring on it before it went in my car.
    Doesnt really show how the springs sits in the cup, but notice the tighter wrapped coils towards the top
    rear strut
    front strut
    that last one shows how the springs should sit in the struts.
    Apr 2005
    Sounds gud.. Top it is then. Thanks
    90 CRX
    88 LX-i Coupe
    Brighton, Colorado
    yep, no problem
    Apr 2005
    Wait, one more quesiton. On the rears, the tighter end is the end with the coil that just ends, while the wider end is the part that flattens out a bit and can stand on its own. Are you sure the flatter part of the rear goes to the bottom? I mean, it seems to fit best.. But i dont know..
    90 CRX
    bobafett's Avatar
    Stock 86 Accord LXi Hatch
    Longview, WA
    what struts do you have? with tokicos or konis, i know for a fact halxi is right? if u are running a different strut i suppose it COUUUUULD be different, but i dont see why it would. and it certainly wouldnt change the fact that the top hat stlil wants the flatter side.
    Apr 2005
    Well, if you look in those pictures, the side that can stand on its own for the rears is the side with the wider spacing. The fronts, however, are opposite.
    So yeah. :\ BTW: Tokicos.
    90 CRX
  1. How to on how to cut springs on a 3rd gen
    By .:dutchtuner:. in forum Suspension/Wheels/Tires/Brakes
    Last Post: 02-14-2010, 04:34 PM
  2. Springs!
    By GTRSkyline43 in forum Wanted
    Last Post: 07-18-2009, 11:50 AM
  3. Cut my springs
    By accorddog in forum Suspension/Wheels/Tires/Brakes
    Last Post: 04-04-2006, 05:34 PM
  4. Springs
    By SDracerBOY in forum Suspension/Wheels/Tires/Brakes
    Last Post: 08-16-2003, 10:55 AM
  5. springs???
    By almightyaccord in forum Suspension/Wheels/Tires/Brakes
    Last Post: 12-11-2002, 01:35 AM
