I got the gasket kit today and it the right on for the B20A motor i can get them for about 180+Shipping and they here in the us no more overseas here a pic
Is it an ajusa gasket kit?
Where did you get this from?
I need these parts!
Lets get on with the info, I want a set. Where ? Where? Where ?
Phil
i talk to the shop owner and ask his if i can put his shop on here he said no but if you want them i can get them for you it takes about a week for me to get it so let me know it comes with what you see in the picture like i said the cost is $180.00 and the cost of shipping to where you are i dont think would be more then $14.00 at the most
Ajusa makes gasket kits for just about everything, their based in Spain and you can buy the parts seperately as well even valve guide seals etc. My Friend distributes Ajusa in the U.K. to the car parts dealers which is dead handy as i get them all at trade price they seem pretty good i've not had toomany problems with them on my A20's or B20A's the seals are all pretty good don't know how much CR you can push on them before they blow out between cylinders or howmuch boost you can run, i'd be conservative and if you want high CR or Boost then get a copper one made up or you'll risk blowing the gasket across cylinders or into the waterways which will mean head off to put a new one on each time. They'll be fine under normal use and engine specifications but don't expect them to be as good as Felpro Blue gasket they are the Dogs wotsits when it comes to Head gaskets!! Especially if your running High CR or Boost but as far as i know they don't do anything for B20A just ET and A20
Who makes the gasket set? And lets set up a transaction to get me one. I'll paypal the cashola $194.00 + 2.9% = $199.60 so I will just paypal $200.00.
Phil
Can you also get a timing belt?
I need these parts!
carotman on the stock timing belt for the B20A maybe i have not check it out but the Honda P/N is 14400-PM7-004 i am going with the B16 Gears and H23 timing belt on my B20A
If you want a gasket set let me know and i call and on the availablity and how long to get it and i need your zip code for shipping cost.Originally Posted by nswst8
Hey carotman you can have the timing belt that i took off my b20a you just pay the shipping the timing belt looks new let me know.Originally Posted by carotman
should be able to get a belt Gates do them plus others, mine cost me £25 their not much.
06340 is my zip. Let me know
Phil
The kit 180.00 and shipping two your zip code is 12.50 the total is192.50 let me know when you want to do it and i will send you my Pay-Pal info for you can send the money.Originally Posted by nswst8
If you are absolutely sure that this is the correct gasket set, then lets do this, send me your paypal account info.Originally Posted by TWOLOUDNPROUD
Phil
New Gasket and old
PM SentOriginally Posted by nswst8
Hmm, saw something mentioned about the PM7 timing belt? The belt for the Prelude B20A is the same dimensions as the PM7, and is designated 14400-PK2-004. They are both 124 teeth, by 24mm wide. The belt for the the B16 and B17 engines is the same length, but is 26mm. So if you are using adjustable cam gears or something, you can use the wider belt for more strength. Oh, but you'd also need to swap the crank gear for the wider unit too.
Hey, do one of you guys have a pic of the B20 block surface? I see something...
Visit us at www.valleyspecialists.com for all of your Honda and Acura Parts and Service needs!
You mean like this? https://www.3geez.com/attachment.php?...0&d=1031550974
Okay, nevermind... I thought I was going to be all slick and come up with something cool.. But I didn't. All I came up with was that the B20A5 Head has two additional oil galleries on either end, on the intake side. I wonder if they did that because it's got the gangster lean back?
