Results 1 to 6 of 6
Thread: cruise control switch
    Atlanta, GA
    This will sound really dumb: how do you disengage the cruise control switch?
    I just bought this car and it came with no manual. In the glorious hour of testing everything I could find, I made the mistake of pushing the cruise control button in. Little green light comes on. But the button doesn't seem to want to come back out. Either it's broken, or there's some simple way to do it that I don't know. It's not really interfering with anything, but i'd rather not have it on when i'm not using it.
    Thanks
    YK86's Avatar
    Oct 2000
    BC, Canada
    The spring might be broken or there might be alot of dust and crap inside. You can pop it out, take it apart (I thik there was one or two small + screws) and clean it up. Or you can go to the junkyard and get one for $5.
    www.b20accord.com
    Atlanta, GA
    Is it supposed to come back out by pushing it again? If so, it's definitely broken.
    89 Accord LX-i, 5spd.
    LX User bigpoppa88's Avatar
    89 EX-i, 88 Accord LX (parts car)
    Winnipeg, Manitoba, Canada
    big press
    i've had that happen also, try pushing it in again and then let it "snap" back and it will usually pop out. Don't let it release gently, hold it in with the tip of your thumb and let your thumb tip just edge down so it "snaps" out...hope it works for you!
    Jareds 89 LX-i's Avatar
    Apr 2001
    Black '89 Accord LX-i sedan
    Mills River, NC
    Mine used to not want to pop back out too easily either (sometimes at all). I just cleaned it out real good with a can of electrical parts cleaner and it's since worked flawlessly. Try that...it should fix the prob
    -Jared
    AZmike's Avatar
    Jul 2002
    Tucson, Arizona
    Mine has always been stuck, but I never thought of it as a problem. If I want cruise control I hit the steering wheel button. When I want it off, I either tap the brake or clutch. It doesn't hurt anything to leave the system 'on' all the time as far as I know.
    Maybe if I get really bored sometime I'll pull it apart just to see why it's stuck, but I'm in no hurry.
    Mike
  1. cruise controlswitch into a fog light switch
    By Honda Man in forum EFI Tech
    Last Post: 12-13-2011, 07:12 PM
  2. Wiring in a cruise control cancel switch
    Last Post: 01-20-2011, 02:50 PM
  3. cruise control?
    By jaiden in forum 3geez Accords
    Last Post: 03-08-2005, 01:30 PM
  4. cruise control
    By my86dx4dr in forum 3geez Accords
    Last Post: 09-27-2003, 11:04 AM
