This completely sucks for me… I started up my car a couple weeks ago and noticed that none of the belts were moving at all. So after closer inspection, I found that the crank pulley was kind jerking a little bit back and forth. Me and my brother decided to take it out hoping that the crank wasn’t broken. So we took the driver’s side wheel off to get a better look… Took the crank pulley off, and we noticed, TINFOIL around the crank. By this time we both were like WTF? So we took the bottom piece of the timing cover off, and guess what? The belt tensionor for the timing belt was completely out of wack. You could see where it has rubbed a hole through the cover and completely broke it into several pieces. Some dumbass took tinfoil and BLUE SILICONE and patched the timing cover back together and put it back on the car. On top of that it doesn’t look like my crank pulley is the right one… Just when I thought there was intelligent life on this planet.So now I have to buy a new pulley and timing cover. And since I have it all tore apart I decided on buying a new water pump and timing belt kit, cause the timing shot on the car also. And of course a new valve cover gasket. Great luck for me huh? Ne one know of where I can get a complete Timing Belt kit? And how about a timing cover and crank pulley?
