Results 1 to 5 of 5
Thread: Spark Plugs: anti-seize & torque wrench
    SE-i Sedan 5 spd
    I never used a torque wrench to install a spark plug, just relied on my "feel," and have never had a problem. This time, when I went to remove the plugs, the two outer ones (1 and 4) were a bitch to remove. Especially #1, which I had to put a 3' breaker bar on to get it moving. Now that scared me, I had visions of tearing up the plug in the hole, and then what? I had not put any anti-seize compound on the plugs either.
    So I went to Sears and got a torque wrench, the smaller kind that is in the correct range for the plugs, which are 18 newton-meters. I also bought some anti-seize compound. When I went to install the plugs, I was surprised at how soon the wrench "clicked." I've always tightened plugs more. I guess I'm lucky that I didn't strip out some aluminum threads before.
    Moral of my story: I'm a believer in torque wrenching plugs from now on, and using anti-seize compound as well.
    Feb 2004
    89 accord lxi
    down by the bay
    Re: Spark Plugs: anti-seize & torque wrench
    yeah, the manual says only 13lbs.
    Well you can just run your car on 3 cylinders anyways its just very loud (like a tractor) and very crappy. I've done it once but not on purpose, i just forgot to put in the plug
    carotman's Avatar
    Montreal South Shore
    Yeah. People ofter overtorque stuff. I'm always surprised on how soon the torque wrench clicks on stuff like oilpan gaskets, valve cover gaskets and sparkplugs.
    I need to get the bigger torque wrench so I can do the suspension bolts properly.
    I need these parts!
    SE-i Sedan 5 spd
    Bigger torque wrench
    I have a bigger torque wrench too, I use it for the wheel lug nuts. But recently I had a new upper control arm installed, and eventually I noticed a banging when I went over some potholes. Off came the front wheel, out came the shop manual, which said to tighten the inboard mounting bolt to, if I remember, 55 ft lbs. They had it at about 20 or less. Solved the problem, but I didn't get there immediately. What a pain. Anyway, my bigger wrench is the cheaper kind, with the indicator moving across a scale. If I had it to do over again, I'd get one with the twist settings, like my small one. It would also have helped in the close confines of the wheel well.
  1. Best Torque Wrench?
    By vteckiller in forum Classic Honda Community Chat
    Last Post: 05-11-2012, 04:35 AM
  2. Torque Wrench: recommended replacement
    By OptimusPrimeSr in forum Classic Honda Community Chat
    Last Post: 01-24-2009, 09:17 PM
  3. Torque Wrench - Messed Up?
    By it's paid for in forum 3geez Accords
    Last Post: 12-20-2003, 03:25 PM
  4. Anti Seize Applied to Crankcase Pulley Bolt?
    By it's paid for in forum Classic Honda Community Chat
    Last Post: 12-11-2003, 04:09 PM
