Here's the deal,
I bought the car for $100 from my friends sister back in april,
I had her sign the title over, and got it noterized. I lost the title
and just found it the other day, It was burried doen in the couch.
The tag on the car is from april 04, so It's going to be somewhere around
$400 to get it tagged and get a title in my name. So far the 3g has only been driven around the neighborhood. I pulled of the rear brake drums, and
found that one of the springs on the passenger side had somehow broke of and on the drivers side there was a broken metal bar thingy, (not sure what part it is). I was inspecting them because my parking brake does not work,
and I kept hearing this scraping noise from the driver side rear wheel.
It has an automatic transmission that needs an overhaul. The engine sounds
and runs good. The girl I bought it from had recently replaced all belts, including the timing belt, they look brand new. Im not sure If she replaced the water pump while having the timimg belt replaced, but It all works.
There is minor rust forming above the rear wheel wells, and when I open
the sunroof, there is rust around the inner edges, when it's closed you cannot see it. The muffler has holes in it, I think the valve guides, and
piston rings need replacement (not desperately) There are minor dings
and scratches all around, but nothing major. basically It can be saved,
and can be a nice 3g, but I have a $340 ticket to pay from an accident
I was in, and the 3g needs new tires all the way around. It would cost me
tires: $200 all 4
brakes: $400 front and back with new fluid and master cylinder
ticket: $340
tag/title: $400
transmission: $400 ( $90 IF I overhaul it myself )
engine: (all new gaskets) : $80
headlight motor: $50 (driver side headlight motor needs replacement)
muffler: $150?
about: $2020 total for me to get the 3g driveable and legal.
My parents said they'd cover the insurance.
Should I keeep it ,get a job, and put down the money, or just
save the $2020 and get something that doesn't require so much work
and something that has an up to date tag????????????
