I asked around about the different ways to fill the 3 extra holes in the Prelude B21A1 block. Here are the suggestions I recieved:
Weld the holes shut - Would definately work. Would require head shaving. Most expensive option. Cannot be done yourself. Could warp the head if done improperly.
JB Weld - JB weld is rated to 500 degrees, which could be a problem. I would probably not trust it.
Liquid Aluminum Block Filler - Very strong, but can be tricky to use and apply properly. Head would have to be stripped down and cooked in an oven for proper curing.
Liquid Gasket - Can only be used when filling a hole that will be up against the block. Not a permanent solution. Not something that can be safely used for this head swap.
Thread the holes and install plugs - Just tap the holes and install some hex socket plugs (
http://www.midwestsocket.com/HexKeys.jpg). Possibly use loctite red, and turn them in so they are deeper than flush. It was suggested that brass plugs would work the best. I do not know if loctite would be useful because it apparently starts to lose effectiveness at 500 F.
Most people I talked to seemed to think threading the holes for plugs would be the best solution. At this point I would agree.
