Page 9 of 10 FirstFirst ... 5678910 LastLast
Results 201 to 225 of 226
Thread: Swap - ET2 / A18 / B20A (JDM) / B20A5 / B21A : Head - A20A : Block
  1. #201
    '91 Accord Wagon (F22B1 with H23A1 Pistons) '98 Accord LX (Wife's) '88 Prelude Si (B21A1), '85 CR-X Si (D16Z6)
    Salem, Oregon
    Re: Swap - ET2 / A18 / B20A (JDM) / B20A5 / B21A : Head - A20A : Block
    Quote Originally Posted by Swap_File
    Well, it turns out the information I got from preludepower was incorrect, the A20 intake manifold does NOT bolt up to the B20A5 head.
    Sorry about that, I try to dispel crappy information their, but I have been a little busy as of late. I'm still working on this from my end, but I'm also still waiting for a donor block.
    Visit us at www.valleyspecialists.com for all of your Honda and Acura Parts and Service needs!
  2. #202
    Salem, Oregon
    Okay, folks... I have an '87 LX coming in for an engine replacement on monday. So I finally will have a bolck to start this project with. I guess I better spend a little time this weekend and tear down the B21A1 that I'm getting the head from. This is the start of probably three long projects*, so we'll see how it goes.
    * B21A1/B20A Rebuild for the '88 Lude, A20A/B21A1 for, uh, research, and Probable Turbo for the A20/B21.
  3. #203
    Ichiban's Avatar
    North of You.
    As far as a 17 tooth crank pulley with a 25mm bore, i can't find anything. most pulleys from the power transmission manufacturers have an even tooth count, so the best i could think of is a 16 or 18 tooth crank pulley and two 32 or 36 tooth cam gears. thoughts?
    ICHIBAN!
    "Now, even more better!"
  4. #204
    1988 honda accord lxi sedan, 90 pontiac sunbird,
    colrado springs co.
    Quote Originally Posted by guyhatesmycar
    yeeah as long as they fit in the place as the stock gears it should work, if you get this running could you give me a parts list, and does any one know if we can stroke an a20 to a 4 1/4 stroke, becose thats why im loseing, no torque.
    14 sec in the quarter, and all bone stock parts, wanna run money bags?
    besides, who said they had to come from a honda any way?
  5. #205
    Ichiban's Avatar
    North of You.
    change your gearing. trying to make a stroker crank will lead to nothing but problems...could someone with the B21 head post up some specs so i can look for timing gear that will come close to fitting? thanks.
    ICHIBAN!
  6. #206
    Salem, Oregon
    I'm looking in to possibility of the B20A3 Crank in the A20 block. Probably the rods too. In which case I may bump it up to the B20A5/B21 crank with the F22 rods. This should give us the extra length of snout that is needed to line up with the head. If it works, it may just be a goo stroker mod for the stock engine too. I've been rather busy at home lately, so I haven't been able to spend much time in the garage with this stuff.
  7. #207
    Ichiban's Avatar
    North of You.
    ....i'm listening..
    ICHIBAN!
  8. #208
    LX User Sporno's Avatar
    1987 Honda Accord LXI
    Richmond ,VA
    so i could get the B20A5 intake manifold , heads, and exhaust manifold and it would bolt on. i need some strait forward answers . does this project actually work?
    or is it the B21A1 heads and all ... i need to know what to get
    2006 NASA/VCU regional Semi-finalist
    2006 FIRST Robot Rumble Quarter-finalist
    2006 FIRST Robot Rumble - Most Promosing Rookie Drive team.
    2006 Championship Curie division
    2007 NASA/VCU- Regional Winner
    2007 Championship-Galileo
    74+ matches on the feild
  9. #209
    Ichiban's Avatar
    North of You.
    you are gonna have to do a lot of reading to even begin to answer that question.
    ICHIBAN!
  10. #210
    Salem, Oregon
    Yep, you'll need to read the whole thread. But in a nutshell, no. Not without serious machine work.
    The problems to overcome are:
    1) The A20A crankshaft snout isn't as long as the B20/21 cams, so the timing belt won't line up.
    2) The middle head bolt hole on the intake side is in a slightly different spot, and would need to changed somehow. Part of this issue is that the oil pressure channel runs through this hole near the top.
    3) There are two oil drains in the head that need to be plugged, as they have no matching port on the A20 block.
  11. #211
    Ichiban's Avatar
    North of You.
    Quote Originally Posted by Kabuki
    1. Nobody else mentioned the cam/crank pully alignment issue yet? Is this a fact?
    3. If the oil drains face the top of the block, won't the head gasket seal it off effectively enough? unless the hole overlaps the edge of the block, only then will oil pour all over the place. Im gonna check the pic's again....
    Edit: i see the drainback ports there on the intake side, gofast welded his closed, also the oil drainbacks on the front of the head (exhaust side) need to be modified to keep the oil inside the engine
    ICHIBAN!
  12. #212
    Salem, Oregon
    1) Yeah, they did... back in post #195
  13. #213
    Salem, Oregon
    Okay, I also found that the B series cranks (all of them) have a 55mm main journal, rather than the 50mm journal on the A20 block. So that's not going to work either. Then I was also thinking.... Even if we DID fix that, then the oil pump pulley would no longer be in line. So we'd have to mod that too, or replace it with a dry sump...
  14. #214
    snoopyloopy's Avatar
    Killa Cali
    so how does it look now? any more progress?
  15. #215
    Ichiban's Avatar
    North of You.
    Now that i'm going to school in a machine shop for 9 months I'm gonna make the 17 tooth 25mm ID gear. Who wants to try it?
    ICHIBAN!
  16. #216
    Ichiban's Avatar
    North of You.
    yeah if I can get ahold of a JDM B20A head I'll do it myself
    ICHIBAN!
  17. #217
    Salem, Oregon
    Sorry... No progress as of yet. Possibly soon.
  18. #218
    AZ
    this seems entirely too much work you could just swap one of these motors in for that... but i know that you guys just like tinkering so i'll only add those 2 cents.
    dead white and blue
  19. #219
    Quote Originally Posted by stat1K
    yeah that is true..you can fit a b18 with just mounts....but the coolness factor of the a20 block and a DOHC head would be pimp...i will die a happy boy if it ever happens..hehe
    Salem, Oregon
    Just having 16 valves and dual cams for boosting with the iron block would be AWESOME.... Be like a DSM engine... :-/
  21. #221
    Richmond ,VA
    if we could have DOHC heads that would be great for tuning.. with DOHC u can adjust the cams more than SOHC and valves and cam gears and everything it would make for way more power
  22. #222
    Ichiban's Avatar
    North of You.
    So, I'm going to school in the machine shop now...and I'm at the top of the class. My instructor is giving me free rein and backing for my final project, and I think this'd be a good one. What do you all think?
    ICHIBAN!
  23. #223
    you will be my hero if you ever get it to work...lol
  25. #225
    LX User Swap_File's Avatar
    Manual 89 Se-i Accord
    Minnesota
    I finally logged into 3geez after being gone for a few months, and saw a few PMs asking about this project. Here is a quick summary:
    Here is what you would need (Mostly from memory):
    B21A1 (from 1990 - 91) or B20A5 (from 1988 - 91) head from a Prelude. B21 head lowers compression just a bit, B20 head bumps it up just a bit. B20A5 heads are much more common in the junkyards around here.
    Custom lower timing gear (Modify a B20/B21 gear to fit A20 shaft)
    Some other timing belt - Unsure of what is needed
    Tap and plug the extra oil drain holes in the new head
    Redo the one head bolt that does not line up. Probably make the hole in the head a little bigger and oval shaped, and then make a special washer for it.
    Redo the oil feed, since the head bolt that doesn't line up is used with the head's oil system.
    Upper timing belt pulleys do not quite align with the tensioner and bottom pulley. Probably has to have some shimming done.
    You need the B21A1/B20A5 intake.
    I remember that the A20 distributor had a different number of teeth than the B20A5/B21A1. You will probably need to switch to one of the OBD1 ECUs to make tuning simpler. Look for the instructions on what distributors fit on the B20A5/B21A1 head on preludepower.com. The ECU swap is a project in itself...
    My suggestion: Do the head swap if you are looking for a challenge, if you want cheap power go turbo. I am sure that the head swap could be done, but it will not be easy.
    I am currently (slowly) working towards going turbo. College has been keeping me very busy, but I am slowly making progress.
  1. a20a block and 2g uca
    By b20a86lude in forum For Sale
    Last Post: 06-05-2011, 09:56 AM
  2. B20A head To A20A3 block
    By dpax in forum Performance
    Last Post: 05-08-2007, 08:29 AM
  3. It is Possible F20 head on B20A Block
    By accordweber in forum General Engine Swaps
    Last Post: 02-14-2007, 07:57 PM
  4. Has anyone done 86-87 Goldtop B20a to 88-89 A20a swap
    By bullard123 in forum JDM B18A / B20A Swap Tech
    Last Post: 10-30-2006, 08:53 AM
  5. B20A: is a VTEC head swap possible?
    By DarknessRS in forum General Engine Swaps
    Last Post: 12-04-2003, 08:47 PM
