Results 1 to 4 of 4
Thread: A question
    Feb 2005
    89/honda/accord Ex-i
    portland, or
    A question
    Okay.....I finally got my car to start after trying for 4 days. But now, when I go to step on the gas to go, the car wants to die as if it's not getting gas or something. I already know that I have bad injectors, but would that be the reason it's doing what it's doing now?? I am not sure if there's a question like this on the board, that's why I figured I would ask so I would know where to look. Do I need to adjust the idle or do you think there's something else I can try?? I appreciate the suggestions.
    SEi User Deadhead's Avatar
    Jul 2005
    Loveland, CO
    Re: A question
    absolutely it could be that your fuel injectors are screwed.... take them out and soak them in some fuel injector cleaner for 24 hours or so.
    1988 Accord LX-i
    Delaware County
    Re: A question
    Well if your injectors are bad then theres really not too many things i can think of that you can do other then try some good injector cleaner. Let the car warm up and see where your idle is, mine is around 700 or 800 and runs fine, if yours is really low then try to adjust it a little and see if that helps. That's all i can think of without changing the injectors.
    LX User Cant Stop's Avatar
    1989 honda accord lx ,2006 accord se 2.4l i-vtec 166 hp 5spd
    orlando florida
    Re: A question
    hmmm does it run better after running it for awhile? my roommates scirroco runs bad until it warms up then it only runs fair we think the injectors are probably gunked up the car has not been driven properly for about 3 years.
    pic's of project at my homepage: home.earthlink.net/~andyk65
  1. Idle Question / CAI Question
    By MECM in forum Classic Honda Community Chat
    Last Post: 05-16-2007, 10:50 AM
  2. Replies: 4
    Last Post: 08-09-2005, 12:09 PM
  3. Question about 88 Accord and engine swap question
    Last Post: 03-05-2005, 10:49 AM
  4. carb question?/ auto tranny question?
    By accordlxi2.0 in forum Carburetor Tech
    Last Post: 09-25-2004, 03:01 PM
