Results 1 to 7 of 7
Thread: finished my swap, reverse lights not working
    SEi User
    Jun 2005
    1986 Honda Accord POS tranny
    Edmonton AB
    i just finished my 5 speed swap and apparently my reverse lights arent working. i hooked up 2 wires from the transmission into the old gear selector switch and the lights dont work. then i just twisted the 2 wires together and they still dont work. anybody know whats wrong with them?
    Feb 2004
    89 accord lxi
    down by the bay
    Re: finished my swap, reverse lights not working
    did you hook them to the right wires on the shifter? i don't remember what the colors are but on your other post someone said it was the black w/green stripe and the yellow wire. if in doubt, just grab your old auto shifter and use a tester to see which pins on the harness have continuity only when the shifter is in reverse.
    SEi User
    Jun 2005
    Edmonton AB
    Quote Originally Posted by Strugglebucket
    i cut apart my old harness to make a new one for the reverse lights. ive looked at the how-to and loked at the connectors/harness, the lights still dont work. im not completely sure, but its a slim chance its the reverse sensor in the tranny, but its hard to say cause just crossing those 2 wires doesnt do a thing
    SEi User Deadhead's Avatar
    Jul 2005
    Loveland, CO
    just a dumb question here, but did you check to see if your bulbs are good? did they get shorted out when you were doing the swap?
    SEi User
    Jun 2005
    Edmonton AB
    Quote Originally Posted by Deadhead
    my battery was out of the car before i started the swap and they were working perfectly before i even started the swap
    Feb 2004
    89 accord lxi
    down by the bay
    you can check if the reverse sensor in the tranny is working by checking for continuity between the two wires that come from the tranny when you put it in reverse gear.
    SEi User
    Jun 2005
    Edmonton AB
    any cheap ass voltmeter would do the trick wont it? whats weird is, when i just cross the 2 reverse wires, it SHOULD have the lights on, but it doesnt...
  1. Replies: 29
    Last Post: 07-16-2012, 01:29 PM
  2. how do you hook up reverse lights after swap?
    Last Post: 10-27-2005, 07:33 PM
  3. Just finished clear tail lights
    By Morbid Intentionz in forum Interior & Exterior Care
    Last Post: 05-12-2003, 07:49 PM
  4. got my swap finished, now a few problems
    By si accord in forum General Engine Swaps
    Last Post: 04-06-2003, 09:34 PM
  5. Just finished carbed to EFI swap...
    By hornet in forum General Engine Swaps
    Last Post: 07-07-2002, 03:47 PM
