Just tryin to figure out if i need another cable. I installed new clutch / throwout bearing the other day with no problems. Put everything back 2gether and adjusted the cable but noticed no matter how much i tightened it the pedal was still loose. Cranked the car with pedal down (and in 1st gear) the car jumped foward like the pedal wasn't down. I had to snatch it outta 1st to get it back in neutral and now it wont go in gear at all. When we do take up slack on the cable the pedal still engages but not enuff to go in gear. Does it sound like a cable issue or bearing issue? Keep in mind the bearing and Clutch are new.
