well i did the black box removal i still need to tweak it some but now i have a problem which has always been around it leaks oil
as far as i can tell it is leaking from the seperator which has several dry rotted/vulcanized tubes plus the o ring is rock hard that goes to the block.
any one know if this part of the pcv sytem is available on the aftermarket parts scene? if not
any ideas on what size the o-ring might be?
only thing not bad is the box itself otherwise all the hoses and seals are shot.
