Results 1 to 10 of 10
Thread: Help - OVERHEATING
    Help - OVERHEATING
    Need some possible solutions or troubleshooting methods, we just rebult the head, replaced all the gaskets, etc, and now its over hearing again the friggin radiator is just boilding with coolant, like literally yah can hear it boiling. I have no idea, on what else can cause it to overheat. like just running it for 15 mins cause it to boil
    Robs89LXi's Avatar
    May 2003
    '89 LXi Coupe
    Houston, Texas (Home of the Quicksilver project)
    Re: Help - OVERHEATING
    Make sure your thermostat is not sticking. If your return hose to the radiator is not heating up while the supply hose is, then your thermostat is sticking closed. Tap on it a bit (not too much; aluminum housing) and it may pop loose.
    "Feed their greed with your need for speed"
    is there a reason why its boiling in my radiator
    Justin86's Avatar
    Medford, Oregon
    do a compression test to make sure the headgasket is %100, if thats all good maybe a water pump.
    2.0Si User 3G Jester's Avatar
    98 Av6 3oh
    Sacramento, CA
    id put 10 bucks on his thermostat. mine went and caused all kinds of hell.
    i dont want my av6 to hit her teens!!!
    -Travis-
    LX User 88eyeguy's Avatar
    97 Prelude, 97 Suzuki RF600R
    dallas
    air in the coolant lines, says me.
    Four cars (and one motorcycle) in three years and not one with a cupholder...this is the story of my life.
    Quote Originally Posted by 88eyeguy
    Ditto. Happened to me the first time I changed my coolant :P
    LXi User b8er's Avatar
    1987 Ex-i 89 SE-i
    Kelowna, British Columbia
    are the fans coming on at all, if not try changing the thermal sensor in the bottom of the rad.
    -Who needs horse power when you got icy roads and bald tires
    -To drift a car is to create reckless art
    head gasket just replaced, so i know thats good to go, air in the lines, how do i fix that, and thermostat how do i tell if its that.
    SEi User gp02a0083's Avatar
    1989 Lx-i Hatchback
    Jackson, NJ
    thers like a bleeder bolt on the top of the housing
    3Geez resident body man
    Owner of Wreck-less auto body
  1. Overheating
    By MoDawG in forum 3geez Accords
    Last Post: 10-29-2007, 04:21 PM
  2. overheating still ...
    By gekko in forum 3geez Accords
    Last Post: 11-08-2003, 05:24 PM
  3. Still overheating, or so it says
    By mag_pbg in forum 3geez Accords
    Last Post: 11-05-2003, 07:56 PM
  4. car overheating
    By xaccordx89x in forum 3geez Accords
    Last Post: 08-26-2003, 05:59 PM
  5. Car is always overheating???
    By 86exi in forum 3geez Accords
    Last Post: 07-30-2002, 05:44 PM
