I put on some cheap tires a while back that are slightly taller and more narrow. After swapping the tires I have a more noticeable wander, especially at higher speeds; eg, 70. (These tires don't have a symetric tread pattern btw - Kuhmo Power Star 785's. Grooves all go one direction.) I had an alighment done about about 6mos before and the difference was immediate when the tires went on, so an alignment shouldn't be the problem. I knew the struts needed to be replaced and I've done the rears and will do the fronts soon. I figure the ball joints should be replaced as well since they're basically letting the control arms flop around when the car shifts from side to side. So, my question is what other items would most likely contribute to or fix this? The steering is fairly responsive, so I don't plan to replace the tie rod ends. Would ball joints alone probably fix this or should I look for a bushing kit, etc. The rear ball joints are in horrible condition, but I haven't checked the fronts. The rear struts made the car more stable in the corners, but had no effect on the wander. Right now I'm thinking definitely rear CA's or BJ's in addition to regular maintenance - front struts. Just want to be sure I'm not leaving anything critical out. Thanks
