ok so i bought an se-i cause the motor was sized and i finnaly got some time so i pulled the head of the motor ( which i already pulled out ) and i was gonna see if the head was hurt because when i pulled the motor out i took the oil pan off and found out that number 4 cylinders connection rod had fallen off and the rod was completly off the crank journal which made me think that the valves were gonna be toast but once i pulled the head all th vales were fine, not a dent/scratch/nick, nothing, they were all perfect but when i was looking at the piston heads i noticed something weird, the heads had 4 indents for valve spacing, now is this normal?, im thinking not as the a20's only have 3 valves per cylinder not 4 like the piston heads are made for, my best thought is that the motor has been re-build before with the wrong heads. what do you guys think, is this normal or are they the wrong heads, also i guess i can add another check mark to the non-interferrence argument.
