Results 1 to 5 of 5
Thread: rod bearings - undersize vs oversize?
    http://cgi.ebay.com/ebaymotors/HONDA...temZ8015848811
    What would I need undersized bearings for? what would I need oversized bearings for? I thought our bearings are color-coded?
    How do I choose?
    Eric
    Re: rod bearings - undersize vs oversize?
    The color coding is under or over sized. There matching the bearings the dimensions of the crank at the factory. I dont know what color is what bearing.
    shepherd79's Avatar
    Falling Waters, WV USA
    the only way to find out what bearing you need, you have to rip the engine apart.
    You can find more info in shop manual.
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    Yeah, you need to tear the engine apart & plastigauge the main & rod bearings to determine what oversized bearings you need.
    Depending on if you have your crankshaft turned, the machinist will inform you to the appropriate size bearings to buy.
    '91 Accord Wagon (F22B1 with H23A1 Pistons) '98 Accord LX (Wife's) '88 Prelude Si (B21A1), '85 CR-X Si (D16Z6)
    Salem, Oregon
    Yeah, the color coding is stupid. The amount of differences in size are .0001", and there is usually less variation than that in "standard" bearings. We just buy the standard bearing set and mike each unit, and the journals on the crank. then match them up. It's far less expensive (than $11 per bearing HALF from Honda), and works just as well. I'm currently using NDC rod bearings and ACL main bearings & thrust washers in my Accord. No trouble in 8000 miles (1.5 years, just don't drive much).
    Visit us at www.valleyspecialists.com for all of your Honda and Acura Parts and Service needs!
  1. oversize pistons?
    By adk683 in forum Restoration & Custom Fabrication
    Last Post: 07-10-2011, 02:47 AM
  2. IH8 bearings!
    By rfiks in forum 3geez Accords
    Last Post: 11-15-2008, 10:27 AM
  3. ACL rod bearings
    By LiTtLe xOx BitT in forum Performance
    Last Post: 03-13-2007, 02:25 PM
  4. Rod Bearings
    By azazel_18_2 in forum Performance
    Last Post: 11-23-2005, 10:00 AM
  5. hub bearings
    By dXsquared in forum Suspension/Wheels/Tires/Brakes
    Last Post: 11-17-2002, 03:45 AM
