Ok i got a 4ga. kit and i was wondering if there is any hole in the firewall that i can run 4ga. through without having to drill a hole for it..........????
yes, its on the upper most corner of the passenger side. Give me 15-20 min. Ill get pics of how everything is done for you.
i want pics aswell..... i need to run a bunch of wired to dash, but dont know where there is a hole. i looked on drivers side, nuthin there. PLEASE show picks, or else its back to wiring everything through the dang door, and then sometimes, if ur Notlucky, the wire gets cut by the door closing. lol.![]()
V12 Supercharged Toyota Accord
here ya go
passenger side door jam
Rear seat folded down
halxi, all i can say is that i hope it never rains there.
if you look around the firewall, there are some plugged holes that you can fit large-guage wire through. just take a good hard look at your firewall and you'll find them.
does it basically run through my door??? are there any that go through the actual firewall?? cause im runnin tiny speaker wire through the door, and last time i tried through the fender, i could never find the wire..... so i just went the ghetto way....
what you need to do, run a clothes hanger from the door into the fender through the side, then wrap it around the wire and ducktape it, then pull it through. The next problem is trying to get it through down by the heater core, but im satisfied with the result and the time spent
ok, will give it a try, sister took the car at the moment to colledge, will try that when she gets here..... where does the wire go when you get to the door, do i try and get it through one of those panels, or is it open??? can u see the wire when your sitting inside the car???
