Results 1 to 11 of 11
Thread: Rack and pinion seal rebuild kit part number
    SEi User Shane86's Avatar
    Feb 2016
    Florida
    Does anybody have a part number for a rack and pinion rebuild kit ?
    Re: Rack and pinion seal rebuild kit part number
    Any reason you're looking for a kit instead of a rebuilt rack?
    Feb 2016
    Florida
    Yes I have had no luck with remanufactured rack and pinion. The whole time I've had the car I replaced it 4times already with remanufactured ones they sure don't last like the originals
    Feb 2016
    Florida
    4 times in 14 years I guess that's not too bad. It's just funny how the original OEM part will last 20 years before anything goes wrong with it .you're lucky to get two years out of remanufactured Parts same with the starters and alternators
    Mines got some kinda hitch in it but ill hang onto it as long as I can,i dont trust the rebuilds either.
    I know right
    How are they failing?
    Feb 2016
    Florida
    seals under the boots leak
    All of them??? Just the seals on the end? Sounds more like you're using the wrong fluid, or switching fluid or something. If they were hanging up, or grinding or clunking or something, then I would say you're getting bad remans. This doesn't sound like that though.
    Feb 2016
    Florida
    they usually leak on the driver side. I have always used Honda power steering fluid
    DX User Leadpepper's Avatar
    Apr 2017
    1985 Honda Accord hatchback
    Martinsville Virginia
    Guy had my 85 before me had the rack replaced with one from Auto Zone about six months before I purchased the car, after two months of my owning it seals started leaking under boots, Bad so I had to have it replaced again with a remanufured Cardone brand from Auto Zone, all well so far, hope this one stands the test of time
  1. Good part number for M/T pass. side axle seal?
    By G. White in forum 3geez Accords
    Last Post: 07-06-2013, 05:39 AM
  2. rack n pinion
    By allaces in forum 3geez Accords
    Last Post: 10-15-2012, 01:48 PM
  3. Rack and Pinion
    Last Post: 06-07-2007, 05:45 PM
  4. Rack and Pinion
    By c20v6turbo3rdgen in forum 3geez Accords
    Last Post: 04-08-2003, 10:09 PM
  5. how to buy a used ( rack and pinion ) ?
    Last Post: 09-09-2002, 07:30 PM
