I wanted to put a thread together with good tech info on turbos because I am getting lost with all the discussions in the search
ok turbos make boost
I know that and I know a wastegate lets extra exhaust gas past the exhaust wheel and blowoff valves vent the extra intake pipe pressure when you shut the throttle but turbo still has inertia...
I know you need to tap oil feed and return
Stuff I need to know
Selection:
What is a good A/R for a 2.0 A20, power up to 6500 RPMS? Should I choose a t3,, t4. etc? I prefer drivability with a slight dropoff at the top end but really I'm looking for a turbo that can feed it up to at least 6K around 10 PSI
Construction:
When constructing a manifold, are there particular metals I should use/avoid?
What about the welding (tig, mig, etc)?
Ignition:
When boosting I heard that timing needs to be retarded under boost... about how many degrees? Is there a ballpark level or a formula to calculate that? Or do I just try and keep the engine knock level down? Since our distributors are vacuum advance, wouldn't that kill the advance when the turbo makes boost? I think that'll bring it down to the base timing plus whatever the centrifugal ammount is. Maybe I can just retard the distrib a lot and run both vacuum advances for drivability at the low end?
Fuel:
how do I calculate the fuel (lb/hr) requirements for a boosted application?
How does boost affect fuel delivery? I assume it is harder for an injector to push fuel @ 10 PSI vs at 0
I would need a fuel pressure regulator with "boost sensing" right?
ECU
For low-boost applications, can it be as simple as a better fuel pressure regulator that changes the fuel pressure in proportion to the manifold pressure and still remain stoich?
Can I just run a MEGASQUIRT ECU with the right MAP sensor and a wideband O2 sensor and use some kind of other Honda distributor or some other multiple-coil ignition (the megasquirt doesn't control ignition)?
I've read that most Honda ECUs can take up to 11psi, can't I just use any other OBD1 Honda ECU and hook up a Hondata kit to it as long as I hook up the essential inputs like Crank angle, cam position, coolant temp, etc?
Camshaft:
Is it true that our cams have no overlap? I find that hard to believe.. either way wouldn't some overlap acutally help the turbo spool up better by introducing pressurized air to the cyl before the exhaust valve closes?
I'm sure I have a bunch more questions but those are a few to start with... any takers??
Facts (i.e. numbers, experience) are better!!!!
