Ok, now that my other major problem is fixed, the motor mounts, I need to move on to the next big thing in the near future. This engine leaks oil like a sieve!! It appears to be leaking from under the valve cover, around the distributor and/or from under the head near the distributor, from the oil pan gasket, possibly rear main seal, and from some breather looking apparatus that has a tube connected to it leading to the oil pan on the backside of the engine.
I know the oil pan is straightforward, drop the center crossmember and downpipe from the exhaust, and voila, access.
Valve Cover is self explanatory as well....but.....
How do I replace the rear main seal with the engine in the car? Is it possible? Or do I have to pull the crank???
What is that breather on the back of the engine that connects to the oil pan? Oil looks like the oil is more coming from the tube connecting to that thing than from that breather thing itself. Is this a common leaking point?
And am I to assume the distributor is straightforward to replace the O-ring? Just pull the two screws and it should pop right out?
I have to put new CV shafts in the car eventually as they are making noise in a turn, though the boots are in good condition (180K miles on them though). I figure while I had the car down for CV's I would start chasing down and fixing oil leaks.
