i have an 88' accord. about a week ago the air for the heating and cooling would turn off then back on. two days ago it turned off and it's not coming back on. i replaced the blower motor and switch with no luck. anyone have an idea. thanks
Check the blower resisters, or connection where the wiring plugs in. It's located on the underside of the blower housing.
Steve
im checking the resisters and connection but in the middle of it my check engine light came on. the ecu flashes 17 time that tells me the VSS (Vehicle Speed Sensor) is bad. the light has come on before but only when the air is turned on. i dont get it.
fuse is blown?
the fuse is good check them already
