Accordtheory
I don't even have cable tv..ugh..
I would love for someone to give me a definitive answer on why a diesel "can't" run on gasoline.. I do have a couple of my own theories though as far as why an existing diesel can't run on gasoline, but I see no reason why a compression ignition gasoline engine couldn't be built, with the right technology. I think it would all come down to the injector, you would need to get the fuel out into the chamber extremely quickly because of the much higher rate of flame propagation as compared with diesel, but you could do some really awesome shit with this style of engine. Stratified charge combustion with over a 23:1 static compression ratio. Put that in a 5600lb denali, get 30mpg..
I Seriously believe that there are forces in the industry, car companies, oil interests, etc, that are holding back the advancement of technology for their own financial sake. Just look at the shit endyn was building in the 80s, they built pro stock engines that ran over 23:1 compression on race gas, and that trickled down to street engines in the form of cam and piston kits designed to raise the compression and burn the mixture only on the exhaust side of the chamber. (cam profile tailored to avoid piston to valve contact with the raised dome on the intake side. The raised dome would push the mixture into the exhaust side of the chamber) We Still dont have that on production engines. They're halfway there, adding 'quench area' in the chamber, (edelbrock's sbc 'e-tec' heads are a good example of quench with a flat top piston) but they haven't taken it the rest of the way.
one more thing.. I don't know if you know, but saab came out with a variable compression ratio engine years ago. Very simple concept, the cylinders pivot slightly on an axist adjacent to the bottom of the cylinders. I remember thinking that was amazing when it came out, but now I know that concept is obsolete..by lowering the compression that way, you lose the quench, actually increasing your propensity of detonation, while of course lowering your efficiency..
Electric cars are the future, I need to design that ultra capacitor, damn it..Batteries and their associated energy losses will always hold the electric car back. Fuel cells, ultra high energy density capacitors, and electric motors will be the combination for the next 100 years.
