Results 1 to 7 of 7
Thread: explanation of 84-87 arms
    LX User Ace's Avatar
    1992 Honda Accord EX
    North Smithfield R.I
    Cool explanation of 84-87 arms
    Hello
    well my alignment is shot so is my front suspension it bounces squeeks you name it so next year I am going to do everything right. Now I was reading on the 84-87 prelude controll arms. Could someone please explain how exactly these arms compared to the accord arms act to controll the negative camber associated with lowering you're car Thanks Paul
    "Id Rather Be Blown Than Injected"
    Re: explanation of 84-87 arms
    whats up 10 looks no one nows
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    Here is a thread on Prelude Control arms. Click on the link in the first post. That is a how to on them.
    The prelude control arms have a slot in them to bring out the upper ball joint farther. I have a set, cause I dropped my car 2 1/2" in the front. It basically gives you more camber adjustment without buying a camber kit.
    https://www.3geez.com/showthread.php?...e+control+arms
    so basically installing these arms following the how to should solve my camber problems in the front I am dropped with eibach sportline springs. Also for the rear alignment basically we have to get a camber kit for the rear??
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    It should. On the rear, there is a little washer trick I hear you can do. Put a washer or two between the fender well where the upper control arms bolts on to it. There is a thread on here somewhere about it that shows a pic & where it goes. If you want, there are camber kits for the rear too.
    I did an alighmnent on my car & didn't see enough camber to mess with it, but to each his own.
    so the rear seemed fine just the prelude arms seem to be all I should need???
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    Yep..Hopefully you can find a set.
  1. fuel pump relay explanation
    Last Post: 02-15-2013, 09:57 AM
  2. How To: Changing upper control arms/Install Prelude or aftermarket arms
    By snoopyloopy in forum Classic Honda Pics & Videos
    Last Post: 12-20-2006, 09:59 PM
  3. [Suspension, Wheels, Tires & Brakes] How To: Changing upper control arms/Install Prelude or aftermarket arms
    By Vinny in forum How To
    Last Post: 12-20-2006, 07:11 PM
  4. Quick picture/explanation request (blower motor)
    By propr'one in forum Classic Honda Community Chat
    Last Post: 12-16-2006, 01:44 PM
  5. ? on prelude arms, and are they smaller than the accord arms?
    By meanaccord in forum Suspension/Wheels/Tires/Brakes
    Last Post: 02-15-2003, 11:20 PM
