Results 1 to 23 of 23
Thread: Rolling Fenders
    LXi User 2Fast_Fiero's Avatar
    1988 RED Fiero GT, 1985 BLACK Fiero GT
    Albuquerque, NM
    Rolling Fenders
    I'm sure most of you have seen my car, I'm trying to roll the fenders, and I tried following the How To's, but The car is too high up, the tire is too far from the fender, I'm bored and wanted to roll all 4 fenders now so when I drop the car everything will be allready done, If anyone has any sugjestions on how I could roll my fenders, Please speak!
    Albuquerque, NM
    Ok, thank you all for your responses, you were a big help.
    SEi User TeKKnoTeKK's Avatar
    Mar 2002
    88 Accord LX-i 5 spd.
    UT
    anytime bud
    -Aaron-
    SEi User
    Jun 2001
    88 lxi coupe
    gainesville, fl
    use a baseball bat
    tuck between inner fender and wheel..then roll your fenders
    look for it on the web
    forget about it...i got it for you here
    http://integra.vtec.net/wheels/rollfender.html
    Albuquerque, NM
    I said that I did that, I wanted help cus I haven't droped my car yet, I needed something 2 times the size of a bat, what I did was drive one rim in the rear onto a ramp, makeing it do a body bend and causing the tire to get closer to the fender, then I rolled it, I still need to work on it some more, but later. I'm not droping it yet, I just was bored, I need more shit to do.
    2.0Si User pimp86LX's Avatar
    2005 Mazda 3
    Ontario Canada eh.
    use 2 bats
    Albuquerque, NM
    No No NO, what I meant was that my car is soo high up, that the bat I was using was too thin to do anything to the fenders, I'll take pics of what I'm talking about tomorow.
    2005 Mazda 3
    Ontario Canada eh.
    i know man, i was just messin with ya
    Mar 2002
    UT
    lol
    -Aaron-
    carotman's Avatar
    Montreal South Shore
    If it's too high, you don't need to roll the fenders yet
    Wait until it's dropped or you won't be able do do it.
    I need these parts!
    86 Honda Accord LXI HB 5-sp
    Central California
    If he's running the wrong offset on his rims, he will be rubbing the rear fenders with out being dropped. It had that personely happen to me and the car wasn't lowered yet. I might have been able to solve the problem my getting tires that were not as tall, but I ended up getting different rims so, problem solved.
    Now I d
    Albuquerque, NM
    I only did it cus I was bored, ya know, check off one of the things I wanted to do to it, Cus I'm gonna drop it asap and put 17" rims on it with some 40 series tires, BTW, I think I'm gonna run the same rims I have on it, so I might be selling these rims and tires.
    Central California
    If you get the correct offset and tire size 205/40-17 you won't need to roll the fenders, even when lowered.
    Now I d
    Albuquerque, NM
    Well, I'm getting the same offset on the 17" rims, they are gonna be the same, just one inch bigger, and they will have the 40 series tires instead of the 45's, so once I drop it 2"s It might have a problem with hittin the fenders, I'm not done rolling them, I just did them enough for now, cus I was bored out of my mind!
    Central California
    What I'm trying to tell you is that 205/40-17 has the same overall demensions as 205/45-16. It is the next plus size. You may be bored but you really should not need to roll them.
    Now I d
    Albuquerque, NM
    I know, but what I'm saying is, with the car droped, the fenders will touch the tires, cus of my offset, the exact corner of my tires line up the same as the fenders so with it rolled, it will help when I'm droped, Unless I harden the suspension impresivly. cus I've allready mesured where the car will be when I drop it, and the tires will be a few mm's from the fender, and I also live in new mexico so thats another reason why I should roll my fenders when I drop it, the roads aren't smooth.
    Jul 2002
    a pile of lawn ornaments
    Newtown, CT
    hey, so what is the correct offset needed for our cars? I have been running with a cheap set of 15's, but they look damn good, and I know the offset is WAY off on my rims. I know this b/c, well, just look at the pics, and you'll see that it's way off.
    https://www.3geez.com/showthread.php?s=&threadid=4204
    Wheels go right out to the fenders' edge.
    -Mark D.
    2005 Mazda 3
    Ontario Canada eh.
    i believe its between 40-42mm
    i may be wrong
    Jul 2002
    Newtown, CT
    where's Jimbo... ...I'm sure he's got this hard-coded into his mind. All we need now is for his to find his way back to this thread.....
    .....waiting......
    -Mark D.
    Jul 2002
    Newtown, CT
    j/k
    it's all in fun.....
    -Mark D.
    Albuquerque, NM
    Yea well dude your offset isn't as bad as mine.
    Now Imagin that droped to where the top of the tire almost touches the fender.
    Jul 2002
    Newtown, CT
    actually, that's exactly what mine looks like. Except it's that bad with my 15's on. Only thing worse about yours is the wheels kinda bubble out, mine a flat right across the surface from rim to hub.
    -Mark D.
    Central California
    You have to options with offset like that. Get 205/40-16, which is just a little shorter and should give you just enough clerance with rolling the fenders to clear. Or get new rims that have the proper 40-42mm offset (45mm can even work). If you can't bring yourself to those solutions I'll bet money you will never be rub free, even if you roll the fenders.
    And if you move to 17" and insist on getting the same, incorrect offset you won't be able to be rub free since you can't go lower than 40's in 17".
    I'd advertise the rims for sale to VW owners, they use that kind of offset, 35mm. Sell them and get rims with the correct offset.
    Now I d
  1. Rolling Up and Down the 5... Sd to BC.
    By chuck d in forum 2geez Accords
    Last Post: 01-25-2010, 03:03 PM
  2. rolling start at about 10-15 mph
    Last Post: 03-28-2007, 05:56 PM
  3. rolling fenders...
    By superguillermo in forum Suspension/Wheels/Tires/Brakes
    Last Post: 01-10-2005, 06:29 PM
  4. windows not rolling up straight?
    By legend9 in forum 3geez Accords
    Last Post: 09-11-2003, 08:18 AM
  5. rolling idle,surge
    By accordlx-i2 in forum EFI Tech
    Last Post: 05-13-2003, 04:10 PM
