Results 1 to 7 of 7
Thread: shifted into park while the front wheel was moving
    i had my car jacked up and i shifted from park to neutral. i then switched from neutral to park but what i didnt know was that the wheel that was jacked off the ground was moving. when i shifted into park i heard this clicking like somebody put a plastic fork into the spokes of a bicycle. the wheel eventually stopped after about 8 seconds. my question is, could this possibly effect my 1,2,3 or over drive gears? if i eventually lose my parking i dont care but i am conserned about the other gears. keep in mind the wheel was off of the ground and only one wheel was moving and the engine was doing about 2000rmp. next day i changed my transfluid just incase some metal was in the transmission but i didnt see any metal the fluid was very clean as i recently changed it about a month and a half ago. i used honda atf.
    Nov 2002
    1990/BMW/535iA
    New Orleans, LA
    Re: shifted into park while the front wheel was moving
    When you select park, the transmission is physically locked up through the use of a paddle that engages inside. What you heard was the paddle skipping on its indentations in the gear until it slowed down enough to engage completely. No damage done unless you can now move the car in the Park mode. Hope this helps.
    3axap.
    thanks a lot, that is a relief i thought maybe i shortened the life of my tranny.
    SEi User
    Mar 2005
    swifts/sprints boosted
    Saskatoon
    Well it is POSSIBLE that you shortened its life, as you did cause it to do something it shouldnt have, but this is just to spook you, it wont be a noticable differencec, but be careful, its much worse when the car is on the ground and moving. Either way, you should be safe.
    i dont care if i shortened the life of the parking i was just concerned that it could cause problems with shifting and getting into or out of gear.
    3Geez Veteran 87AccordsterLx's Avatar
    Nov 2001
    1991 Supra Turbo W/ 12k Miles
    Wyotech @ Laramie, WY
    That wouldn't have effected your driving gears if that is what you are worried about.
    ~Nathan~
    "There's always something waiting at the end of the road. If you are not willing to see what it is, you probably shouldn't be out there in the first place."
    ~StOcK PiCs~
    Aug 2003
    1989 Honda Accord LX Coupe 5spd
    Heck, I put my dads '90 Accord in park once while still rolling down the street at 5-10kph. Long story. That made some interesting noises, but there were no lasting noticeable effects.
    Doing it with the wheels in the air would have put far less stress on it than I did. I'd say you're 100% fine. Still makes sense to use the parking brake on grades though.
    Honda, The Heartbeat of Japan...
    2004 RSX Type S
    1989 Accord Coupe LX 5spd 2bbl
    Slushies are something to drink, not drive...
  1. Replies: 0
    Last Post: 01-18-2012, 07:00 AM
  2. Front Wheel Bearing Q
    By DBMaster in forum Suspension/Wheels/Tires/Brakes
    Last Post: 01-08-2012, 08:46 AM
  3. Locking up the front wheel
    By bushbean in forum Classic Honda Community Chat
    Last Post: 10-31-2008, 07:18 PM
  4. Shifted from 3rd to 2nd at high RPM's
    By RiCANACCORD in forum 3geez Accords
    Last Post: 02-22-2006, 09:32 AM
  5. Moving the rear springs to the front.
    By Justin86 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 10-05-2003, 03:21 PM
