When I starts engine idle is about 1200 rmp, after run increase to 2200 rmp (choke starts). Problem begins in this moment, choke can't close, even warn up engine. After worm up, idle is still about 2200rmp and I've to drive on open chocke by next 15 min and finally choke close. The second solution: I can stop the engine, wait several minutes, run again, then everthing is ok.
Why doesn't choke vacum close?
thanks for help.
A20A2 engine.
