Results 1 to 25 of 26
Thread: odd engine or already swapped/converted?
    LXi User Vector's Avatar
    88 Accord DX-RWD
    Kelowna BC
    Question odd engine or already swapped/converted?
    a buddy of mine is giving me a 86 prelude that looks to have a 2.0L PGFI 12Valve SOHC engine in it(maybe a20a1 or a3 block?).
    Did these cars come with this engine with EFI or was it converted/swapped away from carbs, maybe even a special edition or somthing?
    frame and body is rusted so bad that it doesnt pass inspections, there for hes willing to give it to me. He did a pretty massive burn out with it and pretty much burned the front tires off of it. Seems like it has alot of power. Idles good and runs smooth.
    I own a 88 Accord DX, so i was hoping i could swap the EFI engine into my car using the guide that is provided here.
    if it is a a20 ... i would like to keep my tranny as it is new and have new cv's aswell, if posible
    3Geez Veteran gfrg88's Avatar
    1986 Honda Prelude 2.0Si-T
    A Mile High.
    Re: odd engine or already swapped/converted?
    dude man i would suggest you get ready to be flamed...
    -Gio
    My E85 Turbo Build
    5280FEST
    88 Accord DX-RWD
    Kelowna BC
    lol... i may have been looking in the wrong spots, but i couldnt find much on the prelude it was mfg'd on 01/86 so i guess it was a possibility that it did come like that. i am somewhat new to this since i used to own 3 escort LX's.
    2drSE-i's Avatar
    1989 Honda Accord SE-i Coupe
    Oklahoma City
    yes its the same engine, a20a3. yours is an a20a1. yes you can swap using hte guide, its the same engine components. use the search function, it is your friend
    '89 SE-i Coupe
    Awaiting Garage
    88 Accord DX-RWD
    Kelowna BC
    wicked ... thanks, thats all i needed to know pretty much, i havent seen to many preludes like that around where i am or just dont know the right people.
    2drSE-i's Avatar
    Oklahoma City
    yeah those preludes are pretty rare. most of them are carbeurated. as long as it has a throttle body and it says PGM-FI on it, your good
    '89 SE-i Coupe
    Awaiting Garage
    Feb 2004
    89 accord lxi
    down by the bay
    i think it's probably a BT. isn't that what the si had?
    88 Accord DX-RWD
    Kelowna BC
    yea PGM-FI is what i meant and 12valve writen on the valve cover. the guy siad that it was aparently swapped, but it didnt look like it to me. i will see it again tomorow during the day i hope this time ... i will try to take some pics and see if i can find a number off the engine to. i thought the SI was DOHC
    LXi User b8er's Avatar
    1987 Ex-i 89 SE-i
    Kelowna, British Columbia
    oo buddy, was this from a white lude? im from kelowna if it is i know the car and the guy who swapped it and the motor, if it is the car defiantly let me know, add me to msn [email protected] or PM me
    2drSE-i's Avatar
    Oklahoma City
    BT's were a3's werent they? just different codes?
    '89 SE-i Coupe
    Awaiting Garage
    Feb 2004
    89 accord lxi
    down by the bay
    yeah.
    2drSE-i's Avatar
    Oklahoma City
    thot so, yeah ur swap is no prob, use the how to
    '89 SE-i Coupe
    Awaiting Garage
    1987 Ex-i 89 SE-i
    just keeping you guys up dated, i was talking to the man yesturday, he lives near me and i was looking at some pics he sent me, definatly looks a20, i never new the BT's were a20's just a different code, i think he said hes getting the car pretty soon, il get him to find the actually staped code and we will all know for sure
    88 Accord DX-RWD
    Kelowna BC
    horray.... its a BT1 had a closer look today.
    SEi User racerx's Avatar
    May 2003
    87 Honda Accord DX
    Colorado Springs
    that's an A20A3 engine then. I'd get to swappin that.
    www.stein-photo.com
    born to XLR8
    carotman's Avatar
    Montreal South Shore
    Unless the engine has less milleage than yours, I would't use it. The wiring harness is a bit different than the Accord, the fuel lines and fuel pump is different.
    You can swap the manifolds and parton on your current engine and use 86-87 Accord stuff to complete the conversion (I would use 88-89 stuff IMO tough).
    One thing for sure, use that Prelude tranny on your Accord!
    1987 Ex-i 89 SE-i
    so is there anything different between the engines? just the staped code? compresion ratio? if you were to just swap the heads would you incounter any problems, ie. pistons hitting vales, that kinda stuff, just curios
    1991 Civic STD
    Arbutus, MD, Baby
    you'd be fine, i think
    Daily Drivers Done Right
    88 Accord DX-RWD
    Kelowna BC
    the engine in the lude has less 7000k less than the accord. either way i will be probably looking at at rebuild soon since both cars are around 300,000k.
    1987 Ex-i 89 SE-i
    ok so i went down to my buddys dads machine shop and checked the gasket books, and just to clarify the a20a1/a2/a3/a4/BS/BT1 all share the same gaskets so that pretty much means they are all the same motor i would asume anyways, so yes i just wanted to tell you all and put the info on the site just incase it wasnt already
    88 Accord DX-RWD
    Kelowna BC
    ok so if i swap just the manifold and the throttle body and i going to get the same power gain as the preludes bt engine? or should swap everything including tranny... the prelude engine does have about 7000ks less than my accord. when i drove the prelude to my house from the lot it feels like it has alot more power. could be also that my accords carb royaly untuned ... i dont know.
    carotman's Avatar
    Tha A20A1 has a higher compression ration than the BT1
    2drSE-i's Avatar
    Oklahoma City
    its a horrible tune, other than that the prelude has a better tranny. but yes you will have the same power because basically you are converting your engine into the same engine.
    '89 SE-i Coupe
    Awaiting Garage
    88 Accord DX-RWD
    Kelowna BC
    so if the a20 has higher compression than the BT.... then i would be better off just to convert mine to efi rather than just swaping it.
    thanks i now go make plans.
    Ichiban's Avatar
    North of You.
    my honda builders book gives me a CR of 9.3:1 for the 88 and 89 A20A3. i would assume the 87 A20A3 and the 86 BT1 would be the same, the only performance change coming in 89 with a new exhaust manifold, yes no?
    correct me if i am wrong.
    Kelowna eh? im about 4 hours east in castlegar...building my bt1 powered 2g hatch.
    ICHIBAN!
    "Now, even more better!"
  1. how is any given swapped engine positioned in the engine bay?
    By newaccorddriver in forum General Engine Swaps
    Last Post: 09-22-2007, 06:31 AM
  2. Headlight leak (H4 converted)
    By AC439 in forum 3geez Accords
    Last Post: 10-16-2006, 07:10 AM
  3. Replies: 7
    Last Post: 03-23-2006, 08:22 AM
  4. converted secondary to manual .... i think !!!
    By skull1441 in forum Performance
    Last Post: 03-11-2004, 11:23 AM
  5. engine swapped cars vs my LX-i
    By wickedaccord in forum General Engine Swaps
    Last Post: 06-21-2002, 08:07 PM
