Can I use any kind of sound deadening on the outside on my sub box to avoid flexing and air leaks?
a good box shouldnt leak a bit. unless your pushing some major subs with bad ass amps, then nah. even then i dont think i've ever seen anything on the outside of a box. i'd get a new box if its leaking the bass out. dunno how a box would really flex, cuz mdf is some solid and hard shit.
what makes you think there is even any flexing at all??????
Flexing sub box? Damn Ive seen it all but a box that actually flexed, if it would flex it would cause all sorts of trouble. I wouldnt worry about it, just get a good box.
wtf? o.O is it made out of fiberglass? are u talking about a bandpass box? if that's the case, just tighten the screws up a bit, or take it apart and put some 3m double sided tape and then screw it back up again...
if ur talking about a regular ported/sealed mdf box....and it's flexing, there's deffenetly something wrong homie.
you can fiberglass/caulk/putty the joints so there are no leaks
